Like Tree2Likes
  • 1 Post By letsboogie351
  • 1 Post By Chicagowil
Old 05-11-2023, 10:06 AM
Cobra Make, Engine: Classic Roadsters LTD, carbureted 302 engine with Offenhauser intake manifold, Edelbrock 4 barrel carburetor, 5 speed.
Default Interior Door Panel Replacement
Has anyone had to replace the door panel on the passenger side in their CR? Mine is looking a bit worn out. I'm wondering if a standard panel will fit or if the CR cars have longer doors with the extra length? I found these at Shell Valley but when I contacted them, they were pretty sure they wouldn't fit.
https://www.shellvalley.com/index.cf...rod/prd111.htm
Old 05-11-2023, 02:39 PM
letsboogie351's Avatar
Cobra Make, Engine: Kenmer with Ford Quad Cam Boss 260
Go and see your local motor trimmer. I'm sure he/she could help you. Either make a new door card or re trim both existing.
johno42 likes this.
Old 05-15-2023, 03:42 PM
MaSnaka's Avatar
Upholstery shop should be able to make you something similar. I doubt those SV units would fit. I need new ones too.
Old 05-16-2023, 02:50 PM
Chicagowil's Avatar
The only other door car even close is on an Excaliber- but still different.
Do you have the plastic style door card base? It would be pretty easy to have a car/RV/Boat upholstery shop redo the door cards.
I just installed my cards last week. My car is a CR1. It has the plastic base with a thin sheet of foam and the skin over that. The holes for the plastic insert style clips had never been drilled. That was the hardest part.
I also added the leather door stops that FFR sells for their Roadster.
I had my dash recovered last month- it was $500. She had to clean up the fiberglass a bit more after I removed the cover. She added a thin foam under the black covering. I think it turned out nice.
I should get the dash installed this week. Just finished the carpet today. And then the seats go in.
Thom
"Still plays in the garage"!
Old 05-17-2023, 03:34 PM
Chicagowil's Avatar
Here are a few shots of the door cards & seats installed as well as the carpet.
The carpet & seat colors came with the kit.
I was very reluctant to use the carpet until I saw the recent AC sold in the UK came with this same color!
And, it somehow works OK with the Viking Blue.
If I get tired of it, I can take them out to be redone easily. As I stated before, I already had the dash recovered in black.
rustyrims likes this.
Thom
