Like Tree4Likes
  • 1 Post By Tommy
  • 1 Post By Chicagowil
  • 2 Post By Tommy
Old 01-09-2024, 06:10 AM
Cobra Make, Engine: Classic Roadsters Ford
Default Headers Sidepipes
Looking for headers and side pipe and would like recommendations. I live in PA
Running a 351c 4V head's. Looking what who you guys used on your builds.
Old 01-09-2024, 07:04 AM
Tommy's Avatar
If you can't find something off the shelf to your liking, take a look at GP Headers. They made custom stainless headers for my Cheetah.
74proii likes this.
Tommy
Previously owned EM Cobra
Old 01-09-2024, 07:15 AM
Chicagowil's Avatar
The headers for the CR are very different than any other kit used. And you have the added difficulty of it being a 351 block which locates the headers at a higher position in the engine bay.
Custom made will be the way to go.
The other option is to use an under-body exhaust system giving the car the look of a street style 427 car. You could possibly use Fox body style shorty headers down to the frame and then low profile (oval) mufflers tucked under the chassis. The tailpipes could either route over the rear end or exit out the side just before the rear wheels. No chance of "snake bite".
I seriously considered it for my car but the header cutouts had already been made when I purchased the unfinished kit.
Thom
"Still plays in the garage"!
Old 01-09-2024, 08:27 AM
Chicagowil's Avatar
Hardfacer likes this.
Thom
Old 01-09-2024, 01:08 PM
Thanks for the feedback. Was thinking about the under car exhaust dumping in front of the rear tires but thought it would put excess heat through the floor. Was not aware that 351 exhaust ports sit higher.Thanks for the insight.
Old 01-10-2024, 05:44 AM
Cobra Make, Engine: Classic Roadsters, 347 stroker
You can also get the headers and pipes from Shell Valley and then have someone modify them for fitment. That’s what I am doing. Having the headers “tweaked” and then the side pipes lengthened to fit. .
Old 01-10-2024, 05:46 AM
Old 01-13-2024, 08:48 AM
Hapnyny's Avatar
I just had East Coast Headers in LI NY build me new headers and side pipes. I dropped the car off and picked it up 10 days later. He built everything from scratch.
Old 01-15-2024, 09:32 AM
It going to be interesting, and a tight fit. I do think some of the posts realize the size of the The primary tubes for that motor are 1 7/8" inch. Most of those options work for 302's/351w's. Yours is a completely different ballgame. FE's clear better because of how the exhaust is, 4v's are massive by comparison. Pay no attention to the "port plate" crowd for that motor btw. I see a lot of restriction in your future. I would be worried about the passenger side clearances. Its' going to be custom, like modifying a set of Coyote headers. I did find these awhile back that should do the trick for you:
https://www.stainlessheaders.com/i-3...tml?q=351c+4v+
Old 01-15-2024, 04:00 PM
Tommy's Avatar
This pic shows the mocked up headers I sent GP Headers and the finished set they sent back. The dimensions were identical. They provided the parts needed to make the mock up.
74proii and CompFi like this.
Tommy
Old 01-16-2024, 01:56 PM
Yeah those build kits are really sweet.
Old 02-09-2024, 04:52 PM
I got the headers from Shell Valley and just ordered the side pipes. They will make a set with longer mufflers for the CR. Everything is Raw Steel that way I can modify if needed.
Old 02-09-2024, 04:55 PM
I got the headers from Shell Valley they had a set for 351C in stock, and just ordered the side pipes. They will make a set with longer mufflers for the CR. Everything is Raw Steel that way I can modify if needed.
Old 02-16-2024, 10:54 AM
cobrarkc's Avatar
Cobra Make, Engine: Contemporary 482 all aluminum Tunnelport Self built and owned since 1980 frame#0000017 and owner of frame CCX 33961 looking for an FIA body to go with it
Tubular Automotive specializes in cobra headers for various brands
Cobrarich
Tags
classic roadsters, headers, sidepipes
