December 2025
Old 05-08-2002, 11:24 PM
ronzara's Avatar
Cobra Make, Engine: Everett-Morrison 351w assembly STILL in progress
Send a message via AIM to ronzara Send a message via Yahoo to ronzara
Default Need Ford Engine Harness for CR
Hello, I have one of your wiring harnesses, But it was missing the Engine Harness,... How do I get one, and what would it cost?? Thanks.
ronzara@hotmail.com
Ron Zara
ronzara@hotmail.com
1. "Putting a Chevy Motor in a Shelby Cobra is like CUSSING IN CHURCH!"...... ME
2. "Friends Don't Let Friends Drive Junk"....
Old 05-09-2002, 06:13 AM
Double Venom's Avatar
Ron,
Have you called Pete at CR's? He should be able to ship one right out if he has them in stock. 1-800-373-9000. Sorry don't know the cost. The harness' have been a major thorn in Pete's side for the last few months. The manufacturer was way behind in shippng them to CR's. He may or may not have one in stock.
IF they are back ordered, let me know, I may be able to come up with one I can "loan" you until the new stock arrives.
DV -- 300 Cobras are NOT enough! Are you registered?
Old 05-09-2002, 08:29 AM
dscott's Avatar
Cobra Make, Engine: Owner, Classic Roadsters II
Ron, I may have one in stock also. Between me and DV we should be able to get you running!
Don
Old 05-10-2002, 06:26 PM
Cobra Make, Engine: Classic Roadsters, Tweaked 351W, T-5Z, CRII Tech Support Team.
Depending on how you're wiring your motor and engine compartment, you might want to just make one. Very few people use the OEM '74 - '78 components. CD ignitions, electric fans, a newer style alternator and/or starter, and you're rewiring most of it anyway. Food for thought.
Old 05-10-2002, 07:19 PM
Jack,
It still works pretty good, especially when the "other" still all plugs in to the main harness. All you really need to do is eliminate the voltage regulator wires if your using the new style alternator.
The electric choke, dist., (even if you use and MSD type box), oil pressure, temp. gauge. fan ? can't remember if the fan is in the engine harness or the front harness, etc. If a guy is really good at wiring, make one, if not then it's much simpler just to eliminate what you don't need.
My 2 cents anyway.
DV -- 300 Cobras are NOT enough & I've got a new toy..I've got a new toy and I aint tellin'
Display Modes
