Old 07-22-2002, 11:38 AM
petek's Avatar
Cobra Make, Engine: CRL, 351W, Tremec TKO
Default Rear Coil Overs (hey Don)
Don,
Got the coil overs mounted to the rear in about a half hour. Quick, easy install. Two questions: the shock body is mounted to the lower mounting point, right?
Second question (in an attempt to save a tiny bit of time), where do you normally set the coil over (measurement from the bottom of the threads to the adjusting "nut").
THANKS!!!!
Pete K.
Who is John Galt?
