February 2026
Old 07-24-2002, 04:45 AM
Club Cobra Member
Cobra Make, Engine: CLASSIC ROADSTERS 427 with a FORD 5.0 bored and stroked to 331cid, BRODIX alum heads, roller rockers, B303 cam.
Default Fuel System Questions
WHERE IS THE BEST PLACE TO MOUNT MY ELECTRIC FUEL PUMP?
I am thinking of mounting my CARTER electric fuel pump in the space between the fuel tank and the frame on the passenger side. The pump inlet will be 4 or 5" above the bottom of the tank and will have about 28" of line to the tank outlet. I WAS also going to use a FRAM cartridge filter between the tank and pump, but it is pretty big and hard to package. It's probably overkill for my setup anyway. What kind of filter should I use?
I'm also going to re-rout the 3/8" fuel line down the passenger side since I'm not using an engine driven pump. This will give me a more direct line to the EDELBROCK carb. How does this set up sound ?
I think by the time this project is done I'll have enough left over parts to build another car !!
Old 07-24-2002, 05:47 AM
Double Venom's Avatar
Mike,
Sounds exactly like the way we install ours. Use a large filter from Jegs or Summit. If you have installed the steel "L" or 3" angle between the rear frame rails for your 4-point seatbelts, then you can hang the pump and filter from it.
Sounds like you are making good progress!
DV
Old 07-24-2002, 06:07 AM
dalola's Avatar
Cobra Make, Engine: Project "X" underway....twin turbo V6, AWD...
Lightbulb
Mike,
Take a look at this setup from Permacool. I think it's a better system than the Fram canister type. I'm using it with great success. Never underestimate the importance of a quality fuel filter! Try to avoid those cheap little inline filters you find at Wal-Mart.
Good luck,
Dave
http://www.perma-cool.com/Catalog/Cat_page26.html
