Old 02-03-2003, 01:51 PM
PSB's Avatar
PSB PSB is offline
Cobra Make, Engine: RCR SLC, Graziano 6-spd, LS3
Question Making a Lemans fuel cap safe?
DV,
In the insurance thread on FFCobra, you mentioned that there is an easy way to modify a Lemans gas cap to make it safe. Please elaborate - I want to make mine safe!
Pete
Old 02-03-2003, 03:29 PM
What? You mean there NOT safe?
Ernie
Old 02-03-2003, 03:43 PM
Mr.Fixit's Avatar
If you get a fuel cell with a bladder and foam, as you should, it ought to have a one way valve on the filler and on the filler vent. Otherwise when your cobra flips over, gas will get to pour out the 2" diam hole, then get ignited by the sparks from your rollbar as you skid upside down onto the infield. The easy way is to insert a plastic locking gas cap into the lemans assy, look at a newer SPF to see what I mean by that.
Old 02-03-2003, 03:55 PM
How about some specifics.
I don't have a SPF to look at!
I have a finishline cap that I would like to make a safe as possible.
gn
Old 02-03-2003, 04:14 PM
Chaplin's Avatar
ERA has started putting a locking cap underneath the LeMans cap similar to what you'd find on productin car (althought their cap is metal, not plactic). This way you can screw it down close, the LeMans cap and not worry.
Maybe Bob Putnam can post a pic?? Bob you there??
Replica is not a dirty word.
Old 02-03-2003, 04:42 PM
Mr.Fixit's Avatar
Basically it's just a plastic fill spout shoved into place, with a locking gas cap on it, all of it fits under the lemans latch and you wouldn't know it was there.
Old 02-03-2003, 04:48 PM
Chaplin's Avatar
Mr. Fixit-
That's the idea, but I think the whole assembly was metal. But I could be wrong, I only looked at it for a second.
Old 02-03-2003, 05:33 PM
Aussie Mike's Avatar
To be road legal in Australia there has to be a non venting cap under the LeMans filler cap (just one of the many registration requirements). It also has to have the restrictor and flap in it so you can only use unleaded fuel. The filler neck also has to be vented to a carbon canister.
I think the big safety issue is that in a roll over the LeMans cap could pop open and dump fuel everywhere.
I'm in the process of machining out the center of the boss on my cap to fit all this in. I've done one before so it isn't too much of a hassle. I'll post some pics when I get it finished.
We must really love these cars down here to go through all this stuff to get one on the road.
Mike Murphy
Melbourne Australia
Old 02-03-2003, 05:52 PM
Double Venom's Avatar
Mr. Fixit!
SPF started machining a double threaded insert for their lemans caps in 1998 (?), right after it was their car that flipped at Run N Gun, ripping loose the cap, igniting and almost resulting in fatal injuries to the driver.
This is nothing against SPF, but rather a, "Jolly good job!" This could have happened to any number of different Cobras. SPF addressed the problem and came up with a solution!
They immediately came up with a machined insert that would screw into the lemans cap, then an OEM cap would screw into it!
Fuel cell? I'm all for it, but at close to a grand per for a "real" fuel cell, I don't see many people dropping the cash. A simple plastic gas tank posing as a "fuel cell" to me, is no better than a good qualty steel tank, surrounded by steel frame.
PSB, sorry to take so long to answer your questions. The Fling III, the new Insurance threads, and with the business, I am running full tilt!
To make a cheap, simple and safe fule entry apparatus, or simply called a gas cap:
Go to almost any auto dealership, Ford, GM, Chrsyler, OR for about 5 bucks your local salvage yard. I suggest a FORD SUV, or Dodge VANS. Remove the fuel insert, with cap. Find one that is a plastic insert or liner. Should unsrcew by simply removing four or five small bolts/screws.
Modify the inside collar of the lemans cap by simply grinding it out. Grind out enough that the lip that holds the cap will fit in. Insert from the bottom! Then simply adjust the lemans cap center screw to close. Two things may help you with a "fitment" problem. The screw will have to be ground to far, or you will have to cut a notch in the actual fuel cap for clearance.
If by chance you cut the cap out to far and actualy cut through, throw it away, right after you go to the local parts store and ask the guy for a variety of caps until you find one with a lower center section.
That's it. Short simple, cheap and very, very safe.
DV..now answer the question! How many of you are running a functional neutral safety switch!
Old 02-03-2003, 07:14 PM
The Excalibur had that covered. Open the flip top and UNSCREW the standard Ford gas cap connected to the "charcoal" filter mounted just ahead of the front tire.
So,,,there I was doing SCCA one day and the dam Charcoal cannister fell out, I runned over it, squirting gas everywhere and shredding plastic like crazy! Amazing it didn't catch fire. Lord knows I've had SOME fires in my time.........
,,,,must have been that screw I took out to put in the brake cooling duct work,,,,,you think? LOL
Ernie
Old 02-04-2003, 02:56 AM
wilf leek's Avatar
DV - And how may people have their electric fuel pumps wired through an engine oil pressure switch??
Another easy way to get yourself hurt.
Wilf
Old 02-04-2003, 03:55 AM
Aussie Mike, I believe Don Pilling at Snake Bite in Queensland has them ready to go for about $70.00.
All torque, no traction!
Anything is possible (if you can justify throwing bucket loads of money at it!).
Old 02-04-2003, 04:23 AM
Hi Andy,
I machined out a cap for Adrian S and fitted one of Don's adapters. I think Adrian had sourced the cap and the adapter seperately. Turned out pretty good but the only problem was that there is no provision for a vent tube in the adapter neck. Adrian had to get a tube welded in later.
Mike Murphy
Melbourne Australia
Old 02-05-2003, 04:36 AM
Its funny how not many things that go into a Cobra fit without being modified! Thats great that your one worked. Cant wait to see your car!
Andy.
Old 02-05-2003, 01:08 PM
Hi Andy,
I've never hear a truer thing.
I've got to get out and catch up with you guys. Do you get down to Doug's workshop often?
Mike Murphy
Melbourne Australia
Old 02-14-2003, 03:35 AM
Yes, every couple of nights I am down there, and some saturdays.
I will e-mail you my number. Hope to see you soon.
Old 02-14-2003, 03:48 AM
427 S/O's Avatar
I've ordered this, get the TC-Cap and 1TN, have it welded in.
http://www.streetrodcatalog.com/manu...ngs-caps.shtml
Perry
