Old 02-12-2003, 05:54 AM
Cobra Make, Engine: classic roadster-351 C
Default spring size
i have a classic roadster using the 1978 chevette rear springs they recommend, having problems with the heigth even with the adjustment screws --running 295/50sr-15 tires. any ideas on a taller spring to use
Old 02-12-2003, 05:57 AM
Cobra Make, Engine: Classic Roadsters 351 Windsor 405 HP
Neutral
Throw away the chevette springs and get a set of coil overs from
Don Scott!!
Old 02-12-2003, 07:45 AM
Double Venom's Avatar
Tid,
The best information yes, is what Art advised. Don and I both carry the correct springs and shocks to cover about any contingency for the rears.
Your rear springs should be 13x 175-225 range. Most guys go with the 175's but if you want to hug the road a little harder try the 200's.
"Pro" or "ALdens" coil overs work well back their too! Same Spring rates please.
DV
Old 02-12-2003, 03:02 PM
dscott's Avatar
Cobra Make, Engine: Owner, Classic Roadsters II
DV, the 175's are too light for the car. The 200's work but they will collapse after time. I use the 225's. I use the Pro-shock SM 600 on the rear with the coil spring, oil filled and light valved. When I use the Pro-Shock coil overs I go with the 250 spring. Works great and gives an excellent ride.
Don
Old 02-12-2003, 03:31 PM
Don,
Hmmm, I'm still using the first set of springs on my personnal DV Cobra and they're 175's. Interestesting, very intersting.
DV..aint more than one opinion great!
Old 02-12-2003, 06:07 PM
dscott's Avatar
DV, are you sure? The stock Chevette springs are 200's and they are pretty light. The problem I always have with the 200's are over time they seem to collapse. If you get 2 guys in the car with my weight it will bottom non stop. The springs that Classic supplies now are 225's. Maybe your springs are metric . Maybe kilograms ! Or I suppose if they are about 2 feet long .
Don
Old 02-12-2003, 07:08 PM
If it wasn't so darned cold, if my baby wasn't wrapped up and all comfy, if I felt like crawling around in the dark, at -4 degrees on the concrete, I'd take a look!
I'll get back to you about MAY!
DV
Old 02-12-2003, 07:29 PM
Ha ha...DV,,,I love that reply! Well put! Of course if it was a customers car I know you'd be out there with flashlight checking it out at 4 am.
Ernie
Old 02-13-2003, 07:11 AM
dscott's Avatar
You big baby! A little cold won't hurt ya. Well, it might hurt you! I know you're getting up there in years and the old bones don't move like they used to .
Don
