December 2025
Old 06-15-2003, 11:34 AM
fxbill's Avatar
Cobra Make, Engine: Classic Roadster 427, 446 cu in Iron Eagle stroker, Trick Flow "R" heads, Comp roller, Edelbrock Thunder 800 cfm, Eaton posi, Richmond 3.27, Tremec TKO 600
Another reason you might consider for using a standard pump.....High volume pumps put an enormous amount of strain on the distributor gear. I ate up three new hardened gears within a few thousand miles using a high volume pump. On recommendation from a good racing friend who has a vast knowledge of small blocks ( Ben Alameda) I changed back to a standard pump.....no more problems...
Display Modes
