January 2026
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
Old 12-28-2003, 07:54 PM
Default Who is Bethania garage???
All,
O.K. I have been absent for a while. My wife and I had a kid 9 months ago, and I believe this is my first time back out here since. Anyway I was reading some old threads when I came across one that mentioned losing front end alignment quite often, and correcting it with either tommy's garage (bethania?) or a strutless package? I am taking my time building my kit, but I would like to do it correctly. I have the Stock upper and lower a-arms with stock strut and Mustang II springs cut down. Should I be looking at switching? I am building a 550+ horse 427. I am going to need every bit of control I can design in.
Old 12-28-2003, 08:28 PM
Double Venom's Avatar
Cobra Hawk,
Congrats on the new addition! Now lets get the old one done. Call my new partner, Jay, at 740-852-5280. We can set you up with all the suspension parts you will need. We can also set you up with Tommy's phone number if you want to go that way!
DV...what ever it takes!
Old 12-29-2003, 05:31 AM
Bonos's Avatar
Club Cobra Member
Cobra Make, Engine: 1967 E-M with 302 Ford
Cobra Hawk,
Bethania Garage (The Snake Doctor) is located north of Winston
Salem, NC. in Bethania, NC. off route US-52.
I have done business with Tom twice and am very satisfied his
service. He is very helpful in knowing what will work in what type of car (manufacture) you are building.
Go to the internet and seek" Bethania Garage" to veiw his web site and get his toll free number and veiw his site then give him a call. You'll be glad you did.
Bonos
Old 01-01-2004, 08:35 PM
Cobra Make, Engine: Classic Roadsters, Tweaked 351W, T-5Z, CRII Tech Support Team.
You can do it the easy way, call DV and get everything you need from one source designed to fit your car.
You can do it the hard way, like I did, before one stop shopping for Cobras became popular.
Used Heidts "D" tubular uppers. They work fine. But all MII uppers slide around, so Tom Beroth with his upper control arm bracket to the rescue. The bracket bolts to the frame, the uppers bolt to the bracket and adjust with shims. No more sliding around.
For lowers, I used RCC Specialty Products lowers (mounts the shock an inch further down for more shock travel, and provides a nifty lift point for the floor jack). Got the entire lower control arms, Carerra coil over springs and shocks, "Long" upper shock mount specific for CR's, and standard strut rods with urethane bushings.
Would have liked to have gone with strut rodless lowers with body off car, but couldn't find anything I thought was strong enough. If you look at the force moments on the front axle (fore & aft when hitting a bump, and twisting in the direction of wheel rotation when applying the brakes) and where the strength and reinforcements are in the CR frame, the strut rod seemed the safer way to go.
I was the one doing most of the griping that the setup was still to stiff, but after a few thousand miles, it softened up, and no complaints since.
Would still like to install Koni shocks in coilover form, but the Carerras are working just fine at the moment. Doubt I'll play with it until Carerras need replacement.
