Old 01-07-2004, 08:00 PM
Question Brake Light
Don:
Got some of the lights going, (i.e., tail, and turn) thanks for the head light wiring info. The manual said to connect wire 165 to the brake light switch and 166 is not used. There is no power to wire 165 or 166. The brake light switch I have is a two prong switch. I will assume that there has to be constant power to the switch? Is there a hot wire that I am missing or what?
Old 01-08-2004, 11:36 AM
dscott's Avatar
Don, use wire # 165 to the switch and wire # 116 for power to the switch.
Don
Old 04-06-2004, 06:35 PM
TC Cobra's Avatar
Cobra Make, Engine: Classic Roadsters; 351w, Crane Cam, AFR 185's
Don,
Where is #116 located?
Can't seem to find it on the fuse block harness.
Thanks!
Dwain
NEVER MIND, found it
All I had to do was look!
