Old 02-27-2004, 06:09 AM
McCobra's Avatar
Cobra Make, Engine: Classic Roadsters 427 C/O w/ Dual Quads
Default Ferrules
Don,
Have you got any of these feerules used on the doors for the side curtains?
I would like to try adapting two of them for the hardtop screw holes.
Thanks, Mike
Old 02-27-2004, 06:10 AM
McCobra's Avatar
Make that "ferrule"
Old 02-27-2004, 07:11 AM
dscott's Avatar
Cobra Make, Engine: Owner, Classic Roadsters II
Mike, I don't have any like that but you can get them from Finishline. 888-436-9113
Don
Old 02-27-2004, 08:47 AM
McCobra's Avatar
Thanks Don
Any black carpet yet?
Old 02-27-2004, 01:26 PM
dscott's Avatar
Mike, I don't have any in yet for sale. We are still filling backorders on almost all upholstery we get in. I'll let you know when I do.
Don
Old 02-27-2004, 04:24 PM
Bruce Edwards's Avatar
Cobra Make, Engine: Hunter with a 4.6 supercharged
MRCOBRA,
I do not think you will get them to work. They have a very small hole and most of the top and side curtain studs I have seen are about the same size as the outside of that type of ferrule. Some one does make one that has a larger inside and is flatter at the top. E-M was using them in the 80's and I am pretty sure I saw them in a catalog someplace. Just can not remember were right this moment.
Bruce Edwards
Gemini Motorcars Inc.
http://home.bellsouth.net/p/PWP-GeminiMotorcars
Old 02-27-2004, 04:33 PM
McCobra's Avatar
Bruce,
Thanks for thinking of that but I actually tried my hartop bolts, which are about 3/8", and they fit inside this ferrule perfectly.
I'll try Finishline next week, but if you remember where you saw the ones that EM used, please post that jic.
Thanks, Mike
Old 02-27-2004, 04:43 PM
Mike,
I do not think those are 3/8 more like 5/16. I have a set at the shop and if you can wait till Monday when I get back in I can measure them for you.
Bruce Edwards
Old 02-27-2004, 09:27 PM
McCobra's Avatar
Bruce,
You're right.
The hold down bolts are 5/16", but the i.d of the ferrules is about 3/8", so the bolts fit pretty well.
Old 02-28-2004, 07:35 AM
Mike,
Ok I am lost. What are you going to do thread the furrules? You said something about "bolts" and most of the kits I have seen are a piece of steel rod.
Bruce Edwards
Old 02-28-2004, 07:41 AM
McCobra's Avatar
Bruce,
The ferrules just protect the hole in the fiberglass and finish off the top of the hole.
There are nuts permanently attached under the fiberglass that the hardtop bolts screw into.
Old 02-28-2004, 07:49 AM
Now I guess I get it. On your car you have nuts in the glass and you are wanting to finish of the and protect the finish on the car by using the furrules as a guide and protector.
I guess that is what threw me as most of the cars i have seen just drop into the hole in the furrule and do not bolt to the car at all.
Sorry I can be a bit thick at times.
Bruce Edwards
Old 02-28-2004, 07:56 AM
McCobra's Avatar
No problem, Bruce.
I appreciate your willingness to help
