Old 05-22-2005, 08:49 AM
Don Don is offline
Default CR Side Pipe Rebuild
A recap on another approach to a side exhaust system, My objective, for the long term, was to reduce the sound level below what most would consider to be normal for the Cobra. I accepted in advance there would/might be a reduction in power, but for my recreational only type of street driving, that was more than OK.
This was the 2nd time redoing the side exhaust system having previously used a muffler from Arizona exhaust. My understanding is Lucien is now retired. Great sound for a V-8, but it was loud.
I searched for a muffler that would approach being quieter , could not find one with a 4" case, 30" length with tapered 3" ends. that met my desires. Called a few of the muffler manufacturers, they had considered a quiet muffler for the Cobra , but doubted whether there is a market. OK, then I would use multiple components and hope for the best.
Purchased the Lo-bak auger muffler with a 5/8" center tube from:
Dave Stuart
Racing Products & Muffler Co
941 West A St
Hayward, CA 94541
510-783-3714
Prior to the muffler , installed the Car Chemistry 3 disc system with the 1/2'' center tube cap
http://www.carchemistry.com/ccexhaust.html
After the muffler , installed the Vortex Insert Cone:
http://www.secureperformanceorder.co...ProductID=2476
For coating, used Swain Technology Ceramic Coating:
http://www.swaintech.com/race.html
A thread on Swain Technology:
http://www.clubcobra.com/forums/show...threadid=61703
The Swain coating is white only, personal desire was for black. Sprayed the side pipes with 1800 degree high temp exhaust paint purchased from Bill Hirsch
http://www.hirschauto.com/newpages/paint.htm
For those in the NorthEast the modifications were done by:
Rick ( Owner )
Frederick's Autoworks
408 Somers Road, Route 83
Ellington CT 06029
860-875-6683
Rick filled all the welds joining the muffler to the inlet and outlet for a better appearance, looks like one continuous system rather than individual pieces
Overall, very pleased with the end result even though still a bit louder, not much, than I wanted.
The appearance as noted above and ceramic coating by itself made the project worthwhile .
Old 05-22-2005, 07:01 PM
fxbill's Avatar
Cobra Make, Engine: Classic Roadster 427, 446 cu in Iron Eagle stroker, Trick Flow "R" heads, Comp roller, Edelbrock Thunder 800 cfm, Eaton posi, Richmond 3.27, Tremec TKO 600
I've been running Lobaks for around a year now. After trying 5 others before them I wouldn't use anything else.
