Old 07-03-2005, 10:28 PM
Cobra Make, Engine: Classic Roadsters 351 Cleveland
Unhappy Ignition Problem
May 27th we became the proud owners of a Classic Roadster Cobra. Been doing some tweeking here and there and have had wonderful help from the posts on this site. Thanks All!!
Now we have a problem that just "started". Car will start, then die when ignition switch goes back to run. Got it home by holding the ignition key. Took the Steering Column apart, bought a new ignition switch, checked all the connections. Put it all back together. Worked Great for about 6 startups. Now is doing the same thing again? We have the Chevette Steering column.
Thanks for any advice --
Old 07-04-2005, 06:41 PM
fxbill's Avatar
Cobra Make, Engine: Classic Roadster 427, 446 cu in Iron Eagle stroker, Trick Flow "R" heads, Comp roller, Edelbrock Thunder 800 cfm, Eaton posi, Richmond 3.27, Tremec TKO 600
See if your system has a ballast resistor going to the coil. When the key is in the start position the resistor is bypassed...when the key is released to the run position the voltage is routed through the resistor instead of around it. Just a thought..... It was a classic problem on my older Corvettes.
Old 07-05-2005, 07:17 AM
dscott's Avatar
Cobra Make, Engine: Owner, Classic Roadsters II
The most likely problem is with the ignition box. If it is the stock Ford ignition the problem you describe is common. The only way to fix it is to replace the box. The other thing is to check the wiring. Check all the connections to the box.
Don
Old 07-05-2005, 09:09 PM
Thanks much -- It was the ignition box. Locaated it and took it off. One of the terminals must have worked loose and it was pretty burned ----- I guess we were lucky.
Thanks for the help
