Old 06-13-2006, 11:16 AM
416rICH's Avatar
Cobra Make, Engine: Classic Roadsters 302LW
Default CR Cobra what is different than other Cobras
hello,I would like to know how the CR Cobra is different than other Cobra replicas.It seems to have a good reputation from what i have read so far.i have read that the door is different ?Is the wheel base or size of the car also changed ? If so was this to make the car more leg room ? lastly is the suspension from a mustang,or from the factory?
Thanks in advance !
Richard
Old 06-13-2006, 12:10 PM
Cobra Make, Engine: Classic Roadsters 351 Windsor 405 HP
The car is longer and wider than an original,the door being cut into the fender does allow easier entrance and egress also the leg room is much more than other replicas I've seen. The suspension is Mustang II but you can use tubular suspension and coil overs front and rear. I was impressed with the solid feel of the car even on rough road surfaces. The tech support from Don Scott and his crew is second to none.
Old 06-13-2006, 12:30 PM
Don Don is offline
What is different?
Don Scott, owner of CR II, and his entire organization. Make sure your comparisons and feedback are based upon CR II, not the original Classic Roadsters.
http://www.classicroadsters.com/c_427.html
Old 06-13-2006, 12:59 PM
Curt C.'s Avatar
I beleive most of us are extremely happy with our CR and Don's Support. Where are you located? I am sure someone in your area would be more than happy to let you see their car up close.
Old 06-13-2006, 01:30 PM
416rICH's Avatar
thanks for your quick replies! Is the car larger to make it better riding or of easier assembly or other reason? I spend my time between Southern California and Las Vegas.
Old 06-13-2006, 02:44 PM
Curt C.'s Avatar
The car has a 94 inch wheel base vs 90 for the original and 92 for some other replicas. This allows for more room. I personally feel that a longer wheel base adds some stability and the car is not quite as twitchy as shorter wheel base cars. That is my personal opinion though. I am in Las Vegas if you would like to see my car.
Old 06-13-2006, 05:05 PM
HI Cobra's Avatar
I have had mine on the road for 5 years and 14k miles. It is a very solid
car. The seats are hard to beat for comfort, you have a wide range of engine choices - there are even a couple running around with Viper v-10's in
them. If you are over 6' tall you will appreciate the additional 4 inches in the wheelbase, with no harm done to the proportions. Plenty of leg room.
As others have said, the support from Don and family is excellent. He didn't
own Classic Roadsters when I bought mine in 1999 but he did provide the
engine and tranny which has worked great.
Flip
Old 08-06-2006, 10:00 PM
fastraxsg's Avatar
Evryday is a roadstr day
Cobra Make, Engine: RHD Hurricane street roadster HM1081 aging nicely in the garage
I've read about how the legroom is better in a CR but how about the foot space, I'm 6-1 but I have a left knee that doesn't bend anymore from a motorcyle accident which means I have to have an auto (yeah, yeah, no autos in Cobras) so I need a space for my size 10+ shoes on the left side. Is there ample foot space there?
aka Fuzzy ............... "It is not the return ON my investment that I am concerned about; it is the return OF my investment".......from Will Rogers
Old 08-06-2006, 11:18 PM
I wouldn't call it 'ample', but it can be modified on the left side to make more room.
Of course with an auto trans the clutch pedal is not there. Now run a 'shortened' brake pedal and 'ample' would apply. Heres a key question to ask when it comes to room on the left side for your feet. Does it have a 'dead pedal'? Thats a pedal used to rest your left foot on while driving, it's next to the clutch pedal but on the floorboard.
Old 08-07-2006, 06:33 AM
fastraxsg's Avatar
Thanks for the info, not sure I could use a dead pedal even if it had one, most of them aren't far enough away to put my foot on, with no bend in the knee it has be to the right length, guess that would be something that can be adjusted, added or deleted without much of a problem during a build. If there was a bit of space between the side wall (left) and the outside panel, I could always due a little bit of creative fiberglassing for a outward curve, assuming the side wall is fiber. Another option is to use a regular size break pedal instead of grocery getter auto brake pedal.
Old 08-24-2006, 10:27 PM
Cobra Make, Engine: Classic ND 427 big block 427 ford with tri power I know the 427 didnt come with tri power just wanted something different. 9 inc. ford rear end top loader four wheel dic brakes.
Don,
Does the Classic rds. 11 have a drop floor?
Old 08-25-2006, 07:41 AM
dscott's Avatar
We have changed the floor pans quite a bit. The front drivers side frame rail was moved in 2" for added width in the footbox and the pan dropped 3". We also dropped the rear pan under the seat about 4" on both sides. The pans are now metal instead of fiberglass. We can now get someone up to 7' tall with no problem. Some of the other changes we made are the addition of 4 point harness mounts, new wiring harness with labeled wires, new heater system, larger Griffin radiator. I also changed over to Ididit columns instead of the GM so we can have dash mounted ignition. The gauges we offer now are similar to the smiths with the reverse speedo and are all electric with the electronic speedo. We've added more adjustability to the doors and the hood. We got away from the old bicycle type door openers and have a nice lever behind the seat on each side. Stainless roll bars are available for each side and we also have a full width 4 point roll bar. We had a new mold made for the bodies and they are really nice. The bodies weigh about 250 lbs and are strong. We just designed a new side curtain for the tops and went with a new front header that slips over the top of the windshield. The clutch and brake pedals have been modified to get closer to a 6:1 ratio on the brake and more throw on the clutch. There are some other minor things also.
Don
Old 08-25-2006, 01:17 PM
Hello Don could you post some pictures of the changes to the chasis and body. Thanks.
Old 08-30-2006, 10:34 PM
1966Snake's Avatar
Cobra Make, Engine: Classic 66cobra/429ci
[quote=Don]What is different?
Don, could you please tell me the difference between the CR II and the Classic Roaster? Thanks!
