February 2026
Old 07-16-2006, 07:39 PM
onefastmustang's Avatar
Cobra Make, Engine: CRII with a Stroked Windsor
Originally Posted by 416rICH
I found the source of the "broken" Trunk door. It was
just the hinge bolt had fallen out and was lying on the
trunk floor. There was no nut to be found.I put the bolt
back with a nylock-nut, that will not come out again.
The passenger door would not open so we pulled out the
back tire and opened the latch access panel.The plastic
cable tie would not hold the cable so we used a hose clamp
to tie it down, so the door will now open!
Next on the agenda is the front suspension ,it is way to hard!
its probably why the car has so few miles on it.
Has any one cut the front shock tower down and welded on a
lower piece so a standard Mustang11 coil over shock would fit?
or is this not a good idea?
Personally I would consider changing them out with the coilover system that CRII sells. That's what I put in mine.
