| S |
1 |
5 |
| 7 |
8 |
12 |
| 14 |
15 |
19 |
| 21 |
22 |
26 |
| 28 |
29 |
30 |
31 |
1Likes
Post By AdamIsAdam
04-29-2007, 04:10 PM
ca
Cobra Make, Engine: CRII with a Stroked Windsor
Tonneau Cover install
Who here has a tonneau cover on thier CR? Do you have any pics of it?? Did you install it and if so was it hard.. ??
I got mine after the car had already been painted so I am a little nervous about drilling into the paint. That and the pictures on the instruction sheet for doing so are a bit dark and hard to make out..
Comments and suggestions welcome..
05-18-2007, 09:26 PM
AZ
Cobra Make, Engine: ACE, 351W, 3550 Tremec, Raging(?) Red W/ White Stripe.
Onefast..., did you already drill and install the fasteners? If you didn't, look in my gallery and see how I hold down the cover I had made at a local upholstery shop.( In the picture titled "Snakes Galore")
I didn't want to have all those pin fasteners for the few times I use the tonneau cover. Different story if you plan on using a soft-top also.
Ralph
SPEED WAS HIGH - WEATHER WAS NOT - TIRES WERE WET - X MARKS THE SPOT
Burma Shave
05-18-2007, 10:26 PM
CA
My car had the cover installed when I bought it. I have never used it in three years. I can see that some of the pins screwed into the fiberglass have caused small cracks and some have chipped the paint. I know the guy with the car before me lived in an area with much cooler weather and possibly rain or even snow. No signs of any water damage thankfully. But he may have used it quite a bit more than I would need to. Make sure you really want it before installing it.
John
01-19-2020, 06:55 AM
NY
Ralph
Old thread, but I'm new here...
@RedSnake351 Can you share the pics of your tonneau you were talking about. I don't see them. TIA
Adam
Fulfilling my lifelong dream to own a Cobra... MISSION ACCOMPLISHED!
MKIV FFR 347 cid, Levy T5, 3.55 3-link.
SOLD  Replaced by something with a Flat-6
01-19-2020, 07:08 AM
NJ
Cobra Make, Engine: Backdraft Car #1209 Roush 427R
Cover
I went little different direction. I found this small mom and pop company that makes these that will match the color of your car. As snap to put on and off. Comes with a case. Fits in trunk.
01-19-2020, 07:15 AM
NY
I saw those here: PiggyBack Covers - Cobra Tonneau Covers - Home
But you can't drive with that on, of course. I'd like one for driving in the rain (which I hope never to do!)
PS How much are those piggy back covers?
Adam
Reason: Price question
01-19-2020, 07:27 AM
NJ
Cost
They were $270. Take about 6 weeks to get. You have to provide exact measurements for an exact fit. Perfect for when the car sits outside at the golf club for 6 hrs to keep the dirt out. Nice people to deal with. My car has never been in the rain and I don't intend to drive it in the rain unless I get stuck. This cover would keep most of the water out if it did rain on it while parked.
01-19-2020, 07:38 AM
NY
Thanks. $270 is not bad at all for what it does. The only problem is, I don't play golf! LOL
Seriously, I figured I'd carry a rain proof car cover for those situations you described.
Adam
01-19-2020, 07:58 AM
AZ
I had a local boat repair/upholstery shop make mine and am pretty happy with it. I use it when traveling and like the fact that the wind doesn't blow things in the passenger area around. I have a couple interior hold down straps that cuts down on the fluttering and even installed some aluminum struts on the underside for the same reason. These were improvements but I just live with the rest of the fluttering. Makes it better for securing stu4ff when stopped for the night or a meal. Of course, bad guys could just un-snap but out of sight, out of mind. Less temptation, I'm thinking.
BTW, I use "LIft-a-Dots" rather than snaps except along the tops of the doors, where I have a couple snaps. Didn't want to lay my arms on the pins for hours.
Karlos
01-19-2020, 08:07 AM
WA
Adam, everything must have went well with Mr. Cox, after seeing the car? I looked at those PiggyBack covers for my Classic Roadster, but a car cover (Outside, waterproof) while sittings works just a well. Indoor I only use the 2-layer, (Cotton) cover light brown, (Tan?) I order one size larger so it lay's down almost to the ground. Cheers Tom.
01-19-2020, 08:21 AM
NY
Tom,
I'm awaiting the report.
Adam
01-21-2020, 08:24 PM
wa
i like to look of it. I really do not like the snaps.
02-22-2020, 11:04 PM
AZ
Cobra Make, Engine: BDR Iconic 427 (Dart SHP-Ford 351W)
To FredG,
The Tonneau is exactly what I'm looking for. Can you please share the contact info.
(P.S. I sent an email to Piggy Back two days ago and have not heard back.)
Thanks
02-23-2020, 08:09 AM
NJ
Gus. This was the contact info I had for them when they did my cover.
pigfarm70@gmail.com or at 678-677-2563 at any time.
02-23-2020, 08:41 AM
NY
Is there any tonneau cover that somehow connects underneath rather than on top of the body? My main gripe with the look of the tonneau is all those "pegs" or whatever they are called, that must be drilled in and stick up when the cover is off.
Adam
02-23-2020, 04:56 PM
AZ
Thanks FredG!
02-24-2020, 04:38 PM
AZ
Placed my order today with PigFarm. Good folks to work with. Looking forward to our new Tonneau cover.
Reason: grammar
