Old 10-17-2007, 11:08 AM
416rICH's Avatar
Cobra Make, Engine: Classic Roadsters 302LW
Default Wind Wing attachment misadventure
In order to obtain a improved fit I filed the two screws that attaches the Wind Wing to the windshield frame.Of course now the screws are too short to fit.does anyone know what size these screws are ,or have extra laying around?They would wish to part with?
Richard
Phased-Plasma Rifle in the 40-Watt Range
Old 10-17-2007, 11:29 AM
MaSnaka's Avatar
Richard,
Take the ones you have to OSH or Home Depot and size them up. Screws are cheap enough to buy a couple different sizes that might work (better than multiple trips to the store). Just be sure they are not too long or that may be an even worse misadventure (cracked windahield). I have a pair of wire strippers that have some holes with threads made to cut screws to length which I find helpful when you just need that oddball size. Good luck.
John
Old 10-17-2007, 12:03 PM
Banned
http://www.southcoaststainless.com/
It might be difficult to find the right polished stainless hardware at the local hardware store. I have used these folks in the past and they should have what you need. Just make sure to order some matching nuts to chase the threads after you cut one down to the correct size. You DON'T want to cross-thread the window frame holes. Install the nut on the fastener, cut the fastener to length, then remove the nut (thereby cleaning up the threads).
Good luck,
-Dean
Old 10-17-2007, 12:22 PM
416rICH's Avatar
John and Dean
Thanks for your reply.i will go to Lowes
to see if i can figure the type of thread used.
Old 10-17-2007, 12:36 PM
Rick Parker's Avatar
Mine used 10-32 stainless screws.
Rick
Old 10-17-2007, 02:08 PM
JBo JBo is offline
Cobra Make, Engine: Ex CSX3327, & AK7113 AutoKraft AC MK IV
go to a Boats US or West Marine, take the one screw with you. They sell stainless marine grade metric and standard and will have varing lengths of many sizes. Had to do this a few times already myself on the same issue. Buy as many variations as you "might" use, keep rest or return as you are talking about 2 bucks for 8 of each size....you'll need them sooner or later.
Old 10-17-2007, 02:18 PM
MaSnaka's Avatar
I have found OSH to carry a better variety of specialty screws than Lowes or Home Depot. Atleast out here they do. JBo has a good suggestion too.
John
Old 10-17-2007, 02:38 PM
wtm442's Avatar
Beam Me Up Scottie
A local ACE hardware store about 10 miles from me carries a ton of SS fasteners. But if they do not have them, I usually order them from the Bolt Depot (its only about 6 miles away and I pick them up).
http://www.boltdepot.com/Default.aspx
Warren
Old 10-17-2007, 05:02 PM
JBo JBo is offline
you now have a lot of alternatives
Old 10-17-2007, 05:27 PM
Banned
Oh, we're just getting started! We haven't even broached the subject on the merits of Gorilla glue, J-B Weld, epoxy and a host of other tool box tricks.
-Dean
Old 10-18-2007, 05:27 AM
Cobra Make, Engine: Classic Roadsters 351 Windsor 405 HP
I jave some left overs ,e-mail me and let me know where to send them
Art
Old 10-18-2007, 06:23 AM
427 S/O's Avatar
I was surprised to find that ACE hardware has a great selection of N&B including SS. Not sure if their in your area?.
Perry
Old 10-18-2007, 08:14 AM
imagine2frolic's Avatar
Cobra Make, Engine: n/a
Send a message via Yahoo to imagine2frolic
DO NOT got to West Marine for hardware unless you want to pay 10x's the cost...........
20mph is not fast, unless you are doing it in a 3/2, 1000sq. ft. house on 10 ft. waves!
Old 10-27-2007, 10:10 AM
Just curious,did the screws I sent you arrive yet?
Old 10-28-2007, 09:41 PM
416rICH's Avatar
Thanks for the above replys!
I used 10-24 SS panhead screws from Lowes.The screw head had to be
trimmed to fit the folding block.Im still not happy with the fit.I wonder if
the builder partially stripped the holes in the frame?
Art ,
email sent
