Old 03-24-2008, 03:57 PM
Cobra Make, Engine: classic roadesters ltd, 302, T5
Default radiator hose part numbers:
I have a 302 ford, using the radiator that CR sent with the kit.
anyone know the hose numbers that I would need for upper and lower.
Thanks bunches.
Ray
Old 03-26-2008, 02:47 PM
Curt C.'s Avatar
just take them down to the local part store and look for ones with similar bends.
Old 03-27-2008, 08:03 AM
Hey Curt: thanks for the idea, would be good if I had some to take down. I have been down the road of trial fitting a dozen hoses until I find one that fits, or I can make it fit. I was looking for the easy way out by just getting a part number. With building customs I should know there is no easy way out.
Thanks much Ray
Old 03-27-2008, 08:07 AM
capteddie's Avatar
Send a message via AIM to capteddie
Thanks bunches.
Ray
You could always go this route. More $$$ but flexible and cool looking.
http://www.coolflex.com/cfm/welcome.cfm
Ed
Old 04-22-2008, 06:12 PM
Cobra Make, Engine: CR, 302 not yet built.
I also have a 302 in a CR with their supplied radiator. Autozone - top hose: XL 3 (sku-37256 00003) Two bottom hoses with a pipe between: 928 (sku-3256 17263) & 135 (sku - 37256 00135). Sorry can't do better w/part numbers. Saved the bar codes. But, the bottom hoses tend to want to collapse at higher RPM. Didn't find this out till I was curving the dist. I put a couple hose clamps on it, seems to have worked.
Old 04-22-2008, 06:57 PM
Cobra Make, Engine: classic roadster,408cu
Default Heres what i did
Jegs ? summit make fittings that adapt 1 3/4 hose end to #16 AN they also make a filler neck that is # 16 AN as well I will try to post pics . WD
Old 05-02-2008, 08:38 AM
Thanks folks, this is more than I knew when I started.
Ray
