February 2026
Old 02-28-2009, 04:00 PM
Dwain,
Just thought of something. The only thing that I did not send you is ferrols for the window posts. Check this site, DV had some information about what material to use and how to install them.
Have fun, Terry
Old 03-01-2009, 12:39 PM
TC Cobra's Avatar
Cobra Make, Engine: Classic Roadsters; 351w, Crane Cam, AFR 185's
Thanks, Terry!
I'm pretty sure I have what I need.
Jim,
That's an idea! Let me think about that...
Dwain
Old 03-05-2009, 03:36 PM
TC Cobra's Avatar
Hey Terry (in CA)!
Top arrived today, thanks!
I notice that there aren't any latches on the ends of the top/front rail.
On tops I've used (borrowed) before there were latches on each end - kinda like you would see on a tool box - that secure each end to the windshield frame.
How did you secure the ends?
Thanks!
Dwain
Old 03-05-2009, 04:30 PM
Dwain,
To be honest with you, I never even installed the top on my Cobra. The snap pins were already on my car. I removed them to give to you. My windshield frame does have some bracket things and there were some in a bag with the stuff that I got with my Cobra when I bought it. I will pop them in the mail to you. Hopefully you can use them.
Edit note, I looked at the brackets and they did not look like the ones on my windshield. So I removed the ones off my windshield and will mail them to you asap. These are just overbent clips. Not latches like on a tool box.
Terry
Old 03-05-2009, 05:24 PM
TC Cobra's Avatar
Hi Terry!
Understand the overbent clips that attach to the windshield frame - I already have those.
What I need would be the "female" part - sort of a rectangular loop attached to a lever that locks by hooking onto the clips and going "over center".
Does that make any sense?
Thanks!
Dwain
Old 03-05-2009, 09:51 PM
Originally Posted by TC Cobra View Post
Hi Terry!
Thanks!
Dwain
Dwain,
Those I do not have and they did not come with the top when i got it. Are there holes in the Alum flange for the rivets for that latch? Does anyone have any pictures of that latch. I am unsure what it looks like. If I can find some at McMaster-Carr I will purchase tham and send them to you.
Terry
Old 03-06-2009, 04:03 PM
TC Cobra's Avatar
Hi Terry!
No, no holes where the latches should be. As DV said, measurments are critical. I'll bet CR expected the installation to be done individually.
On the top I borrowed, and installed on my car, one latch was Ok - the other one was a little loose.
DV, any spare latches laying around?
Thanks!
Dwain
Old 03-05-2009, 07:38 PM
Double Venom's Avatar
Terry,
The small metal loops that are coming at ya go on the windshield frame with the 'loops' at the top. The latches are a hardware/cabinet latch and they are installed by 2 blind rivets on each side, holding the latch in place. Use care on these-measuremnts are everything! Too loose and the top corners can come un-done at speed, to tight and you will not be able to get them to latch.
DV
Old 03-05-2009, 07:56 PM
capteddie's Avatar
Cobra Make, Engine: CRII 351W/408 Stroker
Send a message via AIM to capteddie
DV... Its late! Go to bed! The weather is getting better and I need you well rested to spray paint
"the other ed"
Old 03-06-2009, 05:48 PM
Dwain,
Check out www.mcmaster.com. Look at their latches (or someone elses if you prefer) and let me know which one you want to use. I'll order them and have it shipped to you.
On the McMaster page look up "draw latches" page 2926.
Terry
Old 03-06-2009, 07:50 PM
Dwain,
http://www.mcmaster.com/catalog/115/...l/1889ap1s.gif This looks like the latch- it's "E" if a whole page shows up.
DV
PS.OK, this only shows the latch, follow the link above to tension latches and I have indicated "E" as stated.
Old 03-08-2009, 12:24 PM
TC Cobra's Avatar
Terry/DV,
The "wings" with the screw holes on the "E" model are too wide.
The better fit is model "B", part #1590A43.
Thanks, guys!
Dwain
Old 03-08-2009, 12:55 PM
Dwain,
I will order "2" of them and have them shipped to you.
Terry
Old 03-09-2009, 03:58 PM
TC Cobra's Avatar
Thanks, Terry!
Dwain
Old 03-09-2009, 04:49 PM
-Dwain,
The latches are ordered. I will send you more info as it I get it.
Terry
Edit: Per McMaster-Carr, They will ship today (3-9-09) from the Chicago warehouse.
Old 03-11-2009, 05:47 PM
TC Cobra's Avatar
Hey Terry!
Latches arrived... Perfect!
Thanks!
Dwain
Old 03-11-2009, 08:12 PM
Great, Hope they work out ok.
Terry
Display Modes
