January 2026
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
Old 01-24-2009, 08:38 PM
onefastmustang's Avatar
Cobra Make, Engine: CRII with a Stroked Windsor
Default Electric Fuel Pump in a CR
Hello fellow CR owners...
Have any of you put an electric fuel pump in your cobra? If so where did you mount it? Front? back? By the tank? in the engine compartment?
The reason I ask is I put one on the frame rail but can't get it to pump any fuel. Is there a need to prime these things? It is working as if I take the hoses off I can feel the passing of air.
Old 01-25-2009, 08:56 AM
bump cuz I added more data..
Old 01-25-2009, 09:11 AM
wtm442's Avatar
Beam Me Up Scottie
No electric pump in my Cobra ... just a stock mechanical.
The best place for an electric pump is behind the gas tank, and below the minimum tank fuel level. The best hose location on the tank is on the bottom. The second best is the hole thru the top of the tank next to a normal fuel level gauge/sender.
I've had quite a few electric pumps on other cars, and never ever ever needed to prime one.
Dumb question to the passing air comment ... do you have gas in the tank and is the pick-up below below the gas level?
Do you have a leak in the line from the tank to the electric pump inlet?
Remove the line from the tank at the pump. If you have a small vacuum pump, kook it up and see what happens. You should be able to pull a few inches of gravity. Connect a 8 ft piece of rubber line to the inlet of the pump (... another dumb question - I hope you haven't got the pump in backwards). Stick the hose into a small gas tank and lift the tank to a point higher that the pump. Does the electric pump now pump gas?
Warren
Old 01-25-2009, 11:20 AM
Thanks for the ideas. I am going to mess with it today and see what I can figure out..
Old 01-25-2009, 11:23 AM
Double Venom's Avatar
O.F.M..
Yea, I dont build a CR's without one. I put them on the rear crossmember (behind the seats). No it doesn't need primed. Things to check; I assume it has run before so that would eliminate the pickup problem, do you have negative and positive crossed? (Some pumps will blow a fuse, other pumps can run backwards.) Do you have the inlet/outlets crossed? Simple prolems but they have hapened many times!
Rull of thumb on electric pumps: They are meant more for "pushing" than pulling. Most pump instructions are to put the pump within 18"s of the tank if possible.
Hey, let us know what you found out and when it is working for you.
DV
Old 01-25-2009, 10:18 PM
Well this is where I put my " I had brain surgery so what do you expect" clause...
I had a perfectly good pump but for some reason could not get any fuel pressure. I got very frustrated with it and went to PepBoys and bought a mechanical pump. No go there either so I said WTF. So I hooked a hose and a funnel to the inlet and filled the funnel with gas. I cranked over the motor and it sucked the funnel dry. Then I thought to myself I had removed the soft line from the hard line at the front of the car. Maybe I kinked the hard line somehow. So I pulled the soft line and when I did a piece of electrical tape was over the end of the hard line. WTF tooo... Somehow when I put the soft line back on the tape that was wrapped around the stainless braid had come off and covered the hard line... argh... how frustrating. Anyhow I fixed that and put my pump back in and voila.. We got gas....
Old 01-26-2009, 05:26 AM
Hey!
If it wasn't for silly mistakes this place would really get boring! Well done my friend, but I do have to say that is a first for me
DV
Old 01-26-2009, 06:07 AM
Ron61's Avatar
Post
I ran a Holly Blue one on my Cobra for 12 years and it is still on there working fine. I talk to the guy that owns it once in a while and I mounted it on a cross member just in front of the tank and lower than the top of the tank. I did put a regulator in just in front of the carburetor though as it put out 14 pounds and the carburetor only needed 6 to 8 pounds.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
Old 01-26-2009, 07:31 AM
Originally Posted by Double Venom View Post
Hey!
DV
And to think they let me work on million dollar servers...
Old 01-26-2009, 10:26 AM
wtm442's Avatar
Beam Me Up Scottie
Gimme a D
Gimme a U
Gimme an H
Whatta ya got?
DUH
If that's the worst thing you do on your Cobra, you will be a genius.
Warren
Old 01-26-2009, 11:08 AM
Originally Posted by wtm442 View Post
Gimme a D
Gimme a U
Gimme an H
Whatta ya got?
DUH
I hear that.. How's the weather in Mass. I grew up out there.. But I live in California now.. Love the weather here..
Old 01-26-2009, 04:25 PM
wtm442's Avatar
Beam Me Up Scottie
Cooooooooooooooolllldddddddddddddddddddddddddd.
About 18°F now. The last few nights it was down in the single digits.
The forecast for the next 10 days has the temp between 15 and 35°F.
Cannot wait for spring. I need a ride.
Warren
Old 01-26-2009, 05:00 PM
Yeah.. My dad it was cold. We lived in Northampton. I guess I shouldn't tell you I was just out on my motorcycle and its 70 here..
Old 01-26-2009, 05:43 PM
Now Michael, Be nice
