November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 04-28-2009, 09:03 PM
onefastmustang's Avatar
Cobra Make, Engine: CRII with a Stroked Windsor
Default Header bolts
If you have installed CR headers you know how much fun they can be to get header bolts into them..
What did you guys do to install them? I have a couple that had to be cut to get them in but they keep coming loose so I want to change them to full length ones.
Old 04-28-2009, 10:19 PM
MaSnaka's Avatar
OFM,
My headers were little trouble. I did not have to cut any bolts. 390fe with Sanderson headers.
John
Old 04-29-2009, 03:25 AM
Double Venom's Avatar
O.F.M.,
They are a pain in the arse! But if you use 'flange nuts and bolts they will NOT come loose again. Most of the time you need to put them on after the body is on, a few times, and eddiers is one of them, you can put the pipes on before the body goes down.
After body; I use a 10" extension with a swivel/socket and a 'stubby' (6") combo wrench.
DV
Old 04-29-2009, 03:27 AM
PS
Crap.....are you talking header bolts or sidepipe bolts? Headers: any good header bolt and put the headers on before putting motor in the frame??
DV
Old 04-30-2009, 02:02 PM
Yes sir.. header to block bolts... unfortunately my headers are kind of funky and most header bolts you can't get a wrench on without a bit of cussing.. I wonder if I can send them back to Pete... NOT.....
Old 04-30-2009, 02:38 PM
capteddie's Avatar
Cobra Make, Engine: CRII 351W/408 Stroker
Send a message via AIM to capteddie
ARP and others make some header bolts that have allen heads. Might be able to get an allen socket on easier than a regular socks or wrench.
Like these.... http://www.stage8.com/ford.html
"the other ed"
Old 04-30-2009, 03:13 PM
Use of a "ball headed" allen wrench works great with those type bolts. You can even find them as a 'socket' type.
DV
Old 04-30-2009, 03:16 PM
thanks guys.. Ill get some..
Old 04-30-2009, 04:31 PM
convincor's Avatar
Cobra Make, Engine: FFR 390 toploader IRS
Before you go and buy socket head, take a look and see if you can even get close to go strait(or almost) into the bolt. Lot's of times there's going to be a tube or two that won't let you in.
FWIW, I've had the best luck with 12 point ARP's.
There 3/8-16 bolts only use a 3/8" wrench.
http://store.summitracing.com/partde...0&autoview=sku
FFR MarkIII,FE,toploader,IRS,3.27,Vintage pin's SOLD!
68 F100 Custom Cab 418 cube FE/auto
99 SuperDuty Tuner/chipped/4" Banks TOTALED!!
02 Super Duty 7.3L
Old 04-30-2009, 04:39 PM
Cobra Make, Engine: jbl
i just installed something similiar to these, except using 7/16" wrench, would have used 3/8" if i had them. removed the allen head deals, they suck. put some rtv on the threads to hold them in and you're set.
HI Cobra's Avatar
Convincor,
Those look like what I have on mine. They were more of a
challenge when I had my heat wrap on but since I had them
ceramic coated are easy. I use the 12 pt socket which has
the thinner wall - less interference.
Flip
Old 04-30-2009, 05:49 PM
VECTOR1: "removed the allen head deals, they suck. put some rtv on the threads....."
I guess that why this forum is so usefull- different ideas, different ways....
DV
Ps. "RTV" gets soft or melts at head temperatures. If You really don't want them to come loose use at least RED locktite which you can break loose later 'with' heat OR go with green Locktite!
HiCobra---good point!
Old 04-30-2009, 06:06 PM
sorry, might have been a little strong. i've been up over 30 hrs with prob 2 hrs sleep. i've never had prob with rtv melting though.
Old 04-30-2009, 07:11 PM
Cobra Make, Engine: Everett-Morrison, 434 cid
I've always used silicone RTV in place of header gaskets as well as on the bolt threads- just the cheap, clear, GE from Home Depot. The advise came from one of the header manufactuers (Dynatech I believe) at the PRI show as well as my engine builder. I've never had a header leak or needed to retorque a bolt since following this advise. Vector1, your the first person I've ever heard of, outside of racing circles, that does it this way.
Scott
Old 04-30-2009, 08:19 PM
I do use hi-temp silicone between header and sidepipes and it works great! Header bolts--if it works for ya, why not!
As far as the ball headed allen wrenches, I should have included that the short shaft sockets really do suck as you can't get them in at the 30 plus degree angle you need. However, the long shaft ball-allen wrenches do work just fine.
DV
Old 04-30-2009, 08:45 PM
DV
Thanks for the tips.. I own a set of those.. You have to when you own a Harley Davidson.
Old 05-01-2009, 05:11 AM
Scott
that's the experience i've had. i keep telling people but don't think anybody believes me.
Old 05-01-2009, 05:30 AM
tboneheller's Avatar
Cobra Make, Engine: E.R.A. #505
I have had good results from the ARP 12-poimt bolts.
Old 05-02-2009, 05:27 AM
Seasoned Member
Cobra Make, Engine: Unique 427 S/C, Dart 427W "Replica" Ford engine
Arp also makes 12-point bolts drilled for safety wire. They work.
Bill Stradtner
