Go Back   Club Cobra > General Discussion > Club Cobra Introduction Forum (introduce yourself)
Like Tree1Likes
  • 1 Post By keezling
Old 08-03-2018, 01:06 PM
Cobra Make, Engine: Lone Star Classics- 351W
Default Electronic Fuel Pump
The fuel pump on my longstar classic is very noisy. Does anyone have a suggestion of a fuel pump that is less noisy?
Old 08-03-2018, 02:47 PM
eschaider's Avatar
You should not be able to hear your fuel pump over the sound of your side pipes.
Ed
Old 08-03-2018, 05:39 PM
FWB's Avatar
FWB FWB is offline
Mallory 140 series, #29259, you will need to use a fuel pressure regulator
Fred B
Old 08-03-2018, 06:59 PM
FUNFER2's Avatar
#1....Aeromotive by far. Expensive, but has the fewest problems and longest living.
Kevin
Old 08-04-2018, 07:52 AM
Cobra Make, Engine: FFR fat block tko 600 9"
After several brands of electric pumps left me at side of road, switched to Edelbrock mechanical. Years of no problems and complete glorious silence. Delete switch, wireing relay fuse inertia switch etc. Tow truck driver stated electric fuel pumps are significant portion of his business.
Joey.S likes this.
If aliens are so smart, why do they always choose to talk to guys named Bubba?
Old 08-05-2018, 01:14 PM
Registered User
Cobra Make, Engine: Streetbeast?, 5 speed tran., 351 Ford Windsor Engine with a Holley double pump carb
Smile angyman
I had the same problem, so I purchase a Edelbrock 1725, Mechanical fuel
pump and just install it. Runs great, no more noisy.
Old 08-05-2018, 07:05 PM
RallySnake's Avatar
I ran these Carter fuel pumps for years: https://www.summitracing.com/parts/crt-p4594
Notice I said pumpS? I always ran 2, because you never knew when one would quit.
You can hear the whir when you turn one on, but as soon as you start the engine that sound is gone.
I have just installed Holley Sniper EFI with in-tank pumps. So I have two old Carter pumps available along with an external regulator if you need them.
RS
