440Likes
12-27-2015, 03:37 PM
I have sold to ERA builders previously, mostly FIA models. Please private message me with your email and we can go from there. I do not wish to hijack Bill's thread, thank you.
12-27-2015, 07:18 PM
nc
Cobra Make, Engine: ERA 2092
bracket
sorry about that
12-28-2015, 03:54 PM
12-28-2015, 06:10 PM
SA
Bill....that is so nice
Glen
01-27-2016, 09:43 PM
Finally finished fabricating all the new cockpit aluminum. I modified the frame and remove the inner corner steel pieces of the backbone since my frame has been extensively modified by Bruce. This also required making all the panels from scratch.
Overview of the cockpit. Because I have fiberglass footboxes, I had to fabricate new floors in addition to everything else.
The rear bulkhead includes an access panel for access to the fuel tank and the shoulder harness attachment bolts. You can also see how the inner corners are now squared.
New driver side floor and new 3-piece transmission tunnel top. The forward top cover had to be made in two pieces to accommodate the added dash support tubes. I also decided to make the floors and transmission tunnel sides separate. Just easier for me to fabricate.
The passenger side floor and transmission side panel. I also relocated the e-brake to the floor
I had to cut down the transmission tunnel front panel and then make custom closure panels to cover up the holes between the footboxes and the tunnel side panels.
Under door aluminum to fit the contour of the cutback doors and the fiberglass corner pieces from Bruce. I still need to make door sills with my shrinker/stretcher and attachment panels that tie the under door aluminum to the fiberglass corner pieces.
Used my new Woodward Fab shrinker/stretcher toll to make curved mounting flanges that tie the fiberglass wheel boxes and under door aluminum panels together. Man that was tough going. My right atm feels dead. Material is .040 6061 aluminum 2" wide by 14" long and then bent 90 degrees down the middle lengthwise.
The curved mounting flange was then riveted to the wheel box, and then the under door panel riveted to the flange
Still need to make sill plates to finish off the cockpit
01-28-2016, 01:57 AM
SA
Great stuff Bill. I'm taking a lot of notice.
Glen
01-28-2016, 02:53 AM
Q
There is a LOT to like about this build. Love it!!!
Craig
01-28-2016, 03:32 AM
Neutral
That's some nice looking aluminum work. Great job.
01-28-2016, 05:44 AM
Really impressive. Can't wait to see more.
01-28-2016, 12:25 PM
Verry nice !!!
01-28-2016, 02:21 PM
OR
Are you able to install/pull the tranny from under the car?
ERA FIA 2088
01-28-2016, 03:28 PM
Yes. I still need to cut the hole for the shifter
01-28-2016, 03:38 PM
OR
That's a good thing! You don't know how much work it can be to have to pull that tunnel apart every time you want to get in there. If you have he ability, make sure you can get to the linkages & speedo stuff from under the car. If you ever have to mess with them, you'll thank me. I can get to my linkages. The speedo cable/gear, not so much.
ERA FIA 2088
06-03-2016, 10:55 PM
I have FINALLY reached that point where I am now in the process of taking the car apart so that I can have the chassis powder coated. Once I get the chassis back, then it's on to final assembly. Yeah baby!!
06-04-2016, 01:58 AM
SA
Originally Posted by Bill D
.....Overview of the cockpit. Because I have fiberglass footboxes, I had to fabricate new floors in addition to everything else.
Nice looking dash Bill. What's the third temp gauge for, diff or gearbox? Any problems envisaged for fitting the sensor?
Nice aluminium alloy panelling, by the way
Glen
06-18-2016, 09:22 AM
Glen, the extra oil temp gauge is for the diff.
06-18-2016, 09:23 AM
Out with the old...
And in with the new
06-19-2016, 09:49 AM
CH
How did you get the writing done on the new switch panel?
Looks perfect and is what I would like to do
Driving with your Cobra is fun,
Racing with your Cobra is amazing,
Driving hill-climbing races with your Cobra is.... HAVEN!!
06-19-2016, 10:18 AM
Alf-
I had the panel made.
07-02-2016, 05:57 PM
