Like Tree440Likes
LinkBack Thread Tools Rating: Thread Rating: 4 votes, 4.00 average. Display Modes
  #81 (permalink)
Old 07-03-2016, 06:52 PM
Bill D's Avatar
Brake hardlines and fuel line installed
Rack and pinion installed
jolsen42 and 1985 CCX like this.
  #82 (permalink)
Old 07-03-2016, 07:44 PM
1795's Avatar
Nice work Bill. It takes a lot of skill to bend pipe and make it look good. Nice flow and the powder coating on the frame is real nice as well. Keep up the good work.
Bill D likes this.
  #83 (permalink)
Old 07-18-2016, 08:10 PM
Bill D's Avatar
It's been awhile but I've been busy assembling the car. So here is the latest...
Installed the upper shelf that will be used to support the fuel tank
Then installed the outer and inner panels, and fuel tank restraining brackets
1985 CCX likes this.
  #84 (permalink)
Old 07-18-2016, 08:12 PM
Bill D's Avatar
I then installed the fuel tank, front shelf section, and vent line. The vent line has a gate valve installed. This allows air to move in and out, but should fuel spill into the line, the valve will close
Endless loop ratchet straps keep the fuel tank in place
  #85 (permalink)
Old 07-18-2016, 08:13 PM
Bill D's Avatar
Fabricated, polished, painted, and installed the upper radiator mount
albanycobra and 1985 CCX like this.
  #86 (permalink)
Old 07-18-2016, 08:15 PM
Bill D's Avatar
I had my FFR front lower tubular control arms modified to heim joints. This necessitated fabricating spacers
to fill the space in the lower mount. I made these from .250 wall thick steel tubing, then had them powder coated to match the chassis.
  #87 (permalink)
Old 07-19-2016, 04:03 PM
era cobra's Avatar
Cobra Make, Engine: Contemporary 302 Ford stroked to 347
Looks great Bill. Looking forward to seeing it completed.
Ed
  #88 (permalink)
Old 07-19-2016, 07:12 PM
RACERAL's Avatar
Cobra Make, Engine: Factory 5 mk4 445 FE
Looking great hoss
Al Adkins
Stoneville,NC
My ex car. Sad to see it go.
http://www.ffcars.com/POM/nov2003pom.JPG
  #89 (permalink)
Old 07-19-2016, 07:33 PM
Bill D's Avatar
Started sanding the rad shroud aluminum. Then ran out of sandpaper and energy
Before
And after
1985 CCX and xb-60 like this.
  #90 (permalink)
Old 07-20-2016, 03:42 AM
1795's Avatar
Bill,
Your fabrication skills are amazing. Nice work. For the FFR's, is the fuel cell secured with straps, or is that just a temporary measure to hold it in place until you secure it? That arrangement makes me little uncomfortable
  #91 (permalink)
Old 07-20-2016, 03:46 AM
Cobra Make, Engine: Gardner Doulgas
Very nice build keep posting ☺
  #92 (permalink)
Old 07-20-2016, 04:19 AM
cobrakiwi's Avatar
Great attention to details, very nice build.
  #93 (permalink)
Old 07-21-2016, 03:28 PM
Bill D's Avatar
Spent the last two days fabricating the mounting system for my pusher fans. I used .120 6061-T6 angle aluminum. I made a jig that represented the final design and checked figment. From there I cut all the pieces and fitted them to the jig. After removing the mounting system from the jig, I fit it to the car. A little trimming and it was good to go. I disassembled everything, polished all the pieces, then reassembled them using black 8-32 flat head hex head screws. After everything was tightened up i tested them.
https://youtu.be/TIBl2KYaMss
  #94 (permalink)
Old 07-21-2016, 09:12 PM
xb-60's Avatar
Nice job Bill!
len
  #95 (permalink)
Old 07-22-2016, 05:39 AM
Bill D's Avatar
All wired, wires stowed
  #96 (permalink)
Old 07-22-2016, 08:49 AM
1985 CCX's Avatar
Hey, that hose is a product from our company....
Nice choice.
Bill D likes this.
  #97 (permalink)
Old 07-22-2016, 05:12 PM
Bill D's Avatar
Installed the front suspension, brakes, and wheels and tires
1985 CCX and ScratchBuilder like this.
  #98 (permalink)
Old 07-22-2016, 08:14 PM
RockBit's Avatar
You are doing an excellent job. This is going to be a nice car.
Chris
  #99 (permalink)
Old 07-23-2016, 02:40 AM
xb-60's Avatar
As nice as the FIA body is Bill, it's almost a shame to cover up the work you've put into the chassis fit-out
Glen
  #100 (permalink)
Old 07-29-2016, 10:26 AM
Bill D's Avatar
Spent the day fabricating the 2-piece bottom shelf for the radiator aluminum. The oil cooler will be mounted to the panel later. This piece was somewhat frustrating because the two sides were not mirror images, but slightly different dims. Scrapped one piece and had to start over. Plus it was 98F in the garage. But it's done
