Like Tree440Likes
LinkBack Thread Tools Rating: Thread Rating: 4 votes, 4.00 average. Display Modes
  #101 (permalink)
Old 07-29-2016, 07:54 PM
Bill D's Avatar
Pumpkin installed
1985 CCX and ScratchBuilder like this.
  #102 (permalink)
Old 07-29-2016, 08:00 PM
xb-60's Avatar
You must have a target date looming Bill. You sure are making significant progress there. Well done mate, keep it up.
Glen
  #103 (permalink)
Old 07-29-2016, 10:30 PM
Cobra Make, Engine: Scratch Built with 482 FE
Originally Posted by Bill D View Post
Pumpkin installed
That looks slick! How did you get it in?
1985 CCX likes this.
  #104 (permalink)
Old 07-30-2016, 03:56 AM
jolsen42's Avatar
Way to go Bill. Patience!
John O
Bill D likes this.
jjo42
  #105 (permalink)
Old 07-30-2016, 05:06 AM
Bill D's Avatar
Blood, lots of sweat, and lots of cursing. I placed it on a floorjack nose up turned 90 deg (axles parallel to the 4" tubes). My wife manned the floor Jack while I maneuvered it in place. As she raised the unit, I slowly turned the unit until it pointed towards the front, still turned. Then when it cleared the cage, I turned it to the correct position. After that I just put the hardware and rear mount (which required surgery to clear the ribs on the aluminum case) on. Took two hours and the garage was 96F
Thanks to John O for the link to installing the pumpkin.
  #106 (permalink)
Old 08-31-2016, 07:16 PM
Bill D's Avatar
Rear suspension and brakes all installed
  #107 (permalink)
Old 09-01-2016, 03:47 AM
xb-60's Avatar
Nice, Bill. Very nice.
Glen
  #108 (permalink)
Old 09-01-2016, 02:56 PM
jmimac351's Avatar
Cobra Make, Engine: Building 289 Lemans / FFR mkIV chassis w/ Bruce Chervenak
Bill, what length are those wheels studs?
Pics---> www.jmimac351.smugmug.com
Chief Instructor: www.ChinTrackDays.com
  #109 (permalink)
Old 09-01-2016, 03:44 PM
Bill D's Avatar
Standard but cut down for pin drive
  #110 (permalink)
Old 09-01-2016, 03:59 PM
jmimac351's Avatar
Yeah, I was hoping you found some magic studs for purchase.
  #111 (permalink)
Old 09-18-2016, 05:37 PM
Bill D's Avatar
On to the e brake system. Earlier I removed all the FFR e brake chassis mounts. I then fabricated custom mounts for the cables at the brake calipers, for the end of the cables under the car, and for the Lokar e brake handle. The mounts for the cable ends under the car and the handle were welded to the frame prior to powdercoating.
The brackets for the cables at the calipers bolt to the mustang cobra big brake option
After the floors were permanently installed this week. I tightened everything up and installed the boot and trim ring
1985 CCX and era cobra like this.
  #112 (permalink)
Old 09-18-2016, 07:09 PM
era cobra's Avatar
Cobra Make, Engine: Contemporary 302 Ford stroked to 347
Hi Bill,
It is looking great. Looking forward to seeing the finished Cobra.
  #113 (permalink)
Old 09-19-2016, 01:04 AM
peterpjb's Avatar
what number is that on the vin-plate? do i read csx2929?...
  #114 (permalink)
Old 09-19-2016, 05:21 AM
1985 CCX's Avatar
Vintage Wheels?
Build is awesome................
  #115 (permalink)
Old 09-19-2016, 06:02 AM
Bill D's Avatar
Originally Posted by peterpjb View Post
what number is that on the vin-plate? Do i read csx2929?...
csx 2323
  #116 (permalink)
Old 09-19-2016, 11:08 AM
peterpjb's Avatar
csx 2323
of course, what else 😉
  #117 (permalink)
Old 11-01-2016, 04:42 PM
Bill D's Avatar
Finally got back to working on the car. Made a new dash after ruining the original from FFR. The new dash is made from .060 6061 aluminum. It's padded in marine leatherette with 1/8" padding underneath. It was done by Conejo Upholstery in Thousand Oaks, CA
After cutting the piece to the correct dimensions and using the bottom lip from the FFR dash (my brake isn't wide enough to bend ), I fabricated angle brackets that are riveted and epoxied on the back of the panel. 1/4-20 bolts go thru the hoop and mount the dash to the hoop so the fasteners are hidden.
I had to make a patch panel for the steering column because the dash moved while drilling the hole, damaging it.
I took the panel to a local car upholstery shop since my first go at putting the padding on was a disaster.
I spent the day installing all the gauges, switches, and switch panel
Closeup of the switch panel I had made
  #118 (permalink)
Old 11-01-2016, 04:59 PM
1985 CCX's Avatar
Sweet work.......
Bill D likes this.
  #119 (permalink)
Old 11-01-2016, 05:32 PM
YerDugliness's Avatar
As usual, Bill, splendid work!
Cheers!
Dugly
Bill D likes this.
YD,E./PNB
  #120 (permalink)
Old 11-01-2016, 05:45 PM
Mongoose930's Avatar
Cobra Make, Engine: Hi-Tech
Looks Great!!! Glad to see that I am not the only one who uses my dining room table as a workbench
Bill D likes this.
