440Likes
12-04-2016, 10:05 AM
12-04-2016, 10:32 AM
NC
WOW!
John O
jjo42
12-04-2016, 11:13 AM
I concur! Nice engineering Bill.
12-04-2016, 01:28 PM
Very well done indeed!
12-04-2016, 02:11 PM
VT
Cobra Make, Engine: ERA Slabside BRG 289
Beautiful! Really a work of art.
ERA #3010 Slabside
12-05-2016, 07:17 PM
Reproduction 289 model cast aluminum gas pedal from Cobra Restorers
12-08-2016, 03:31 PM
Cobra Make, Engine: SPO 963, 351W
You got mad skillz, sir!
12-08-2016, 03:47 PM
Cobra Make, Engine: Building 289 Lemans / FFR mkIV chassis w/ Bruce Chervenak
Bill, great stuff. I've got a pile of "original style" wiring that I got from Kirkham years ago. If you have a schematic you're working from I'd love to put it in my stack of stuff.
12-08-2016, 05:17 PM
No schematic. I'm using a painless wiring system. The firewall components are repops but non functional
12-09-2016, 06:00 AM
Cobra Make, Engine: All original, with Chevy engine since 1964
Originally Posted by Bill D
Today I installed a rear brake cooling system. Although not original and really not needed, it still looks pretty cool.
There are only 3 justifiable reasons for doing anything...:
1) It's needed in a functional sense
2) It's a value-adder
or
3) It's going to look really cool.
Yeah, I like reason #3 just as much as reasons 1 & 2.
And who says it's not needed? Someday that car might be out blasting around Willow Springs in the middle of June- When it's 105 out, that track gets HOT....
.. And your car will be ready for it, haha
- Robert
12-10-2016, 11:46 AM
I found these slick little fresh air vent bezels for a 1950-1951 Ford wagon. Using them with my fresh air vent cables.
Cables are simply lawnmower throttle/choke cables
12-10-2016, 02:28 PM
IL
Bill
You don't need cooling on rear brakes..... Just Front Brakes
And your air is just going blow on the surface of one side of the rotor instead of coming in the center and having a backing plate to prevent the air from escaping and then going out the vents in the rotor.... so now you are cooling one side of the rotor and not the other and it will get stress cracks....
Just saying you might want to rethink that idea....
Morris
Morris
12-10-2016, 06:37 PM
Morris,
Well thought out. It might be more of a concern for a jag rear end with inboard brakes on hard high speed braking than on out board brakes, especially under normal braking. However, you do make a good point that if a person were to do provide for venting to rear brakes, that it should be centered on the rotor to ensure equal cooling.
12-10-2016, 06:41 PM
The air is directed towards the center. They're vented rotors. Half of the flange is blocked off somthe air only goes to the center. But I understand Morris' concerns
12-10-2016, 06:42 PM
Original style fiberglass trunkpan, refinished by Jeff Miller, installed
12-11-2016, 06:07 AM
NC
Eggszackly!
John O
jjo42
12-14-2016, 02:47 PM
12-14-2016, 03:54 PM
tx
Good idea. Especially with the webers.
12-15-2016, 04:35 AM
Just remember to pull the pin on the bottle before going out
12-16-2016, 03:14 PM
Trunk inner panels installed
Non-functional vintage SW electric fuel pump installed
