Like Tree440Likes
LinkBack Thread Tools Rating: Thread Rating: 4 votes, 4.00 average. Display Modes
  #141 (permalink)
Old 12-04-2016, 11:05 AM
Bill D's Avatar
Today I installed a rear brake cooling system. Although not original and really not needed, it still looks pretty cool. First I custom made brackets to mount to the rear uprights and installed 3" flanged bases from Aircraft Spruce. Next, I fabricated a mounting bracket for the inlet and then riveted the same style 3" flanged duct mounts to the housing. The housing is mounted to the frame underneath the pumpkin.
The inlet doesn't hang below the undercar exhaust so I should be ok.
I then installed the 3" ducting then installed a wheel to verify clearance. Perfect. No interference.
  #142 (permalink)
Old 12-04-2016, 11:32 AM
jolsen42's Avatar
WOW!
John O
jjo42
  #143 (permalink)
Old 12-04-2016, 12:13 PM
1795's Avatar
I concur! Nice engineering Bill.
  #144 (permalink)
Old 12-04-2016, 02:28 PM
DanEC's Avatar
Very well done indeed!
ERA 782 Running
  #145 (permalink)
Old 12-04-2016, 03:11 PM
Cobra Make, Engine: ERA Slabside BRG 289
Beautiful! Really a work of art.
ERA #3010 Slabside
  #146 (permalink)
Old 12-05-2016, 08:17 PM
Bill D's Avatar
Reproduction 289 model cast aluminum gas pedal from Cobra Restorers
1985 CCX likes this.
  #147 (permalink)
Old 12-08-2016, 04:31 PM
Antny's Avatar
Cobra Make, Engine: SPO 963, 351W
You got mad skillz, sir!
  #148 (permalink)
Old 12-08-2016, 04:47 PM
jmimac351's Avatar
Cobra Make, Engine: Building 289 Lemans / FFR mkIV chassis w/ Bruce Chervenak
Bill, great stuff. I've got a pile of "original style" wiring that I got from Kirkham years ago. If you have a schematic you're working from I'd love to put it in my stack of stuff.
Pics---> www.jmimac351.smugmug.com
Chief Instructor: www.ChinTrackDays.com
  #149 (permalink)
Old 12-08-2016, 06:17 PM
Bill D's Avatar
No schematic. I'm using a painless wiring system. The firewall components are repops but non functional
  #150 (permalink)
Old 12-09-2016, 07:00 AM
moore_rb's Avatar
Cobra Make, Engine: All original, with Chevy engine since 1964
There are only 3 justifiable reasons for doing anything...:
1) It's needed in a functional sense
2) It's a value-adder
or
3) It's going to look really cool.
Yeah, I like reason #3 just as much as reasons 1 & 2.
And who says it's not needed? Someday that car might be out blasting around Willow Springs in the middle of June- When it's 105 out, that track gets HOT....
.. And your car will be ready for it, haha
Bill D likes this.
- Robert
  #151 (permalink)
Old 12-10-2016, 12:46 PM
Bill D's Avatar
I found these slick little fresh air vent bezels for a 1950-1951 Ford wagon. Using them with my fresh air vent cables.
Cables are simply lawnmower throttle/choke cables
  #152 (permalink)
Old 12-10-2016, 03:28 PM
Bill
You don't need cooling on rear brakes..... Just Front Brakes
And your air is just going blow on the surface of one side of the rotor instead of coming in the center and having a backing plate to prevent the air from escaping and then going out the vents in the rotor.... so now you are cooling one side of the rotor and not the other and it will get stress cracks....
Just saying you might want to rethink that idea....
Morris
1795 likes this.
Morris
  #153 (permalink)
Old 12-10-2016, 07:37 PM
1795's Avatar
Morris,
Well thought out. It might be more of a concern for a jag rear end with inboard brakes on hard high speed braking than on out board brakes, especially under normal braking. However, you do make a good point that if a person were to do provide for venting to rear brakes, that it should be centered on the rotor to ensure equal cooling.
Morris likes this.
  #154 (permalink)
Old 12-10-2016, 07:41 PM
Bill D's Avatar
The air is directed towards the center. They're vented rotors. Half of the flange is blocked off somthe air only goes to the center. But I understand Morris' concerns
  #155 (permalink)
Old 12-10-2016, 07:42 PM
Bill D's Avatar
Original style fiberglass trunkpan, refinished by Jeff Miller, installed
  #156 (permalink)
Old 12-11-2016, 07:07 AM
jolsen42's Avatar
Eggszackly!
John O
jjo42
  #157 (permalink)
Old 12-14-2016, 03:47 PM
Bill D's Avatar
Installed the fire suppression system today. First I installed the tank n themtrunk pan
Next I fabricated a mounting bracket for the activation cable from some 1.5 x 1.5 x .125 aluminum angle and attached it to the bottom of the dash
Finally, I routed the tubing to the front and attached the tubing to a nozzle fitted to the firewall
  #158 (permalink)
Old 12-14-2016, 04:54 PM
dallas_'s Avatar
Good idea. Especially with the webers.
Bill D likes this.
  #159 (permalink)
Old 12-15-2016, 05:35 AM
1795's Avatar
Just remember to pull the pin on the bottle before going out
Bill D likes this.
  #160 (permalink)
Old 12-16-2016, 04:14 PM
Bill D's Avatar
Trunk inner panels installed
Non-functional vintage SW electric fuel pump installed
1985 CCX and LMH like this.
