Like Tree440Likes
LinkBack Thread Tools Rating: Thread Rating: 4 votes, 4.00 average. Display Modes
  #161 (permalink)
Old 12-18-2016, 07:34 AM
moore_rb's Avatar
Cobra Make, Engine: All original, with Chevy engine since 1964
Putting the battery flip-flapper up on the dash was a gutsy move from an aesthetics standpoint, but me being a pure "function over form" kinda guy, I think it makes 100% perfect sense, and it turned out looking really awesome to boot... fits the racecar personality of this build perfectly {thumbsup}
- Robert
  #162 (permalink)
Old 01-06-2017, 08:39 PM
Bill D's Avatar
Installed the master cylinders, pedal assembly, and the remaining hydraulic hardlines. Still waiting for fittings to connect the reservoirs to the master cylinders
1985 CCX, xb-60 and CompClassics like this.
  #163 (permalink)
Old 01-07-2017, 08:09 PM
xb-60's Avatar
I think it's the correct place for it too, both from a functional and aesthetic perspective.
Keep up the great work Bill.
Glen
  #164 (permalink)
Old 01-07-2017, 08:14 PM
Bill D's Avatar
Installed the drivers side floor panel temporarily until I'm sure the brakes work correctly and nothing needs to be removed. After that I'll make a cover panel for the hole
1985 CCX likes this.
  #165 (permalink)
Old 01-11-2017, 08:51 PM
Bill D's Avatar
Hoses installed. Ready to fill and bleed the brakes. Will fabricate a heat shield to protect the master cylinders from heat from the exhaust pipes since they run underneath the car.
1985 CCX and LoBelly like this.
  #166 (permalink)
Old 01-12-2017, 04:00 AM
1795's Avatar
Looks nice Bill. Smart idea to install a heat shield as it would not take too long to over heat the brake fluid. It's really coming along. What brake fluid are you planning to use?
After you bleed the brakes, what is the next step?
  #167 (permalink)
Old 01-12-2017, 11:12 AM
Bill D's Avatar
Deleted
  #168 (permalink)
Old 06-16-2017, 02:05 PM
Bill D's Avatar
After taking several months off from my build, I jumped back in with a new found energy and drive. First up was getting the oil cooler scoop fabricated correctly. Two failed attempts by two different places cost me $700 and all I got was junk. This time I transported the body to Full Scale Hotrods in Ventura, CA. Three weeks later, I now have the correct aluminum scoop in was after. It was made with .040 3003 aluminum sheet. The front lip was bent over for the correct look. It was then hand forced into shape, then weld welded to the mounts. It was well worth the $1000
  #169 (permalink)
Old 06-16-2017, 02:07 PM
Bill D's Avatar
Door sills made. Body was "trimmed" to get them to lay flat
1985 CCX, *13* and Riverside racer like this.
  #170 (permalink)
Old 06-16-2017, 03:21 PM
jmimac351's Avatar
Cobra Make, Engine: Building 289 Lemans / FFR mkIV chassis w/ Bruce Chervenak
Atta Boy Bill!!!!!!
Bill D likes this.
Pics---> www.jmimac351.smugmug.com
Chief Instructor: www.ChinTrackDays.com
  #171 (permalink)
Old 06-16-2017, 03:30 PM
Bill D's Avatar
Hooked up a battery charger and checked all the circuits. Everything worked but the horn. After an hour checking the entire circuit inch by inch, I narrowed it to the steering column shaft not being grounded. If the footboxes had been metal, no problem. But the glass boxes insulated it. Had to attach a small wire from the bearing plate in which the shaft passes through in the footboxes to ground. Now the horn works. Electrical complete.
I still have to deal with reworking the door hinges. Currently, when everything is installed, you can only open the doors part way and then the front edge hits the body.
It's unfortunate I wasn't informed of this early on.
  #172 (permalink)
Old 06-16-2017, 03:45 PM
1795's Avatar
Bill,
Great to see that you are back at it. There is nothing that you cannot over come. All of us have to deal with little set backs along the day, but we keep on moving forward. Cannot wait to hear the sound of your can running. Keep up the great work.
JIm
jolsen42, 1985 CCX and Bill D like this.
  #173 (permalink)
Old 06-16-2017, 08:23 PM
1985 CCX's Avatar
Attaboy Bill!
Awesome! Pace yourself.
  #174 (permalink)
Old 06-17-2017, 05:05 AM
jolsen42's Avatar
Way to go Bill. I have complete faith in your abilities!
John O
jjo42
  #175 (permalink)
Old 06-17-2017, 02:22 PM
ALF's Avatar
ALF ALF is offline
Bill is back!!!
Bill D likes this.
Driving with your Cobra is fun,
Racing with your Cobra is amazing,
Driving hill-climbing races with your Cobra is.... HAVEN!!
  #176 (permalink)
Old 06-30-2017, 09:40 AM
Bill D's Avatar
I received a notice from photobucket that they will no longer allow 3rd party hosting unless I upgrade my account and pay monthly. So all my imbedded pics on the cobra forums disappeared. F**k them.
a work around
if you right click on the photobucket image substitution/block thing that says update your account in one of your post and say open in another window, the photo will show up. it a pain but it works.
  #177 (permalink)
Old 06-30-2017, 06:31 PM
1795's Avatar
Bill,
Every time you turn around someone is sticking their hand in your pockets. Keep up the great work.
  #178 (permalink)
Old 07-01-2017, 05:42 AM
jolsen42's Avatar
Bill, please DON'T pull this thread. We can all do the "work around". There are too many guys who have been following this thread. We want to see the finished product.
John O
jjo42
  #179 (permalink)
Old 07-01-2017, 08:51 AM
John O
I 2nd that 😗
  #180 (permalink)
Old 07-01-2017, 09:12 AM
map's Avatar
map map is offline
Cobra Make, Engine: Myself/Body from CSX-2575 & hand built Birdcage
Send a message via Skype™ to map
I'm having good luck with https://photos.google.com/albums.
6S1941
Allied 289 Slab Side
73 2.3 turbo pinto
