440Likes
07-09-2017, 03:49 PM
Custom period correct oil cooler scoop in aluminum
07-09-2017, 04:09 PM
NC
Way to go Bill. Just beautiful!
John O
jjo42
07-09-2017, 04:17 PM
SA
Looks great Bill! The end is getting closer all the time
Glen
07-09-2017, 05:47 PM
Door sills
07-10-2017, 03:53 AM
Bill,
You are making great progress. As usual, great workmanship. It will be a pleasure to see when it is done.
07-10-2017, 07:23 AM
Originally Posted by Bill D
Door sills
Bill,
Great progress!
Dumb question--what are the pop-rivet looking things holding the sheet metal in place?
AC
07-10-2017, 08:08 AM
Those are called cleckos. They simulate rivets but are used to temporarily hold panels in place
07-10-2017, 12:35 PM
Bill,
Thanks. Are they threaded with nuts, or like sheet metal screws?
AC
Edit--Nevermind--Google is my friend:
http://www.panamericantool.com/cleco...FUU6Gwod3FECeg
07-10-2017, 02:59 PM
This video explains better than I could in words
https://youtu.be/lgEIVUVLrnQ
07-13-2017, 07:32 PM
Brake scoops installed. Not original but good enough
07-14-2017, 04:34 AM
Bill, they look great and I doubt anybody is going to get down on their knees and assess if they are original or not. Are you going to leave them flowing straight through or add a deflector up towards the brakes? SPF suggests for their FIA's that if the car is being driven primarily as a street car that the owner consider placing foam or some other blocking material in the back of the scoop as the brake scoops serve no practical purpose in normal driving situations. In addition, it limits the amount of water and road debris that the scoop might throw at the brakes.
I am leaving mine open as it is going to be pure race, but might consider blocking them off if I had a road car. Then again, it never gets that hot up here in update NY. Maybe where you are or in some of the states closer to the equator a little extra cooling might be beneficial.
Keep up the great work.
07-14-2017, 05:58 AM
Thanks Jim. Take a look at the picture again. You'll see red brake hose ducting that is attached to the front spindles. The other end of the hose that is currently hanging loose will attach to the scoops.
07-29-2017, 03:48 PM
It's that time. Time to finally install the drivetrain. Hopefully next weekend after my transmission arrives next week
07-29-2017, 07:33 PM
Your almost there Bill! Congrats. Please refresh my memory, what transmission are you going to be using?
07-29-2017, 07:39 PM
SA
....and which flywheel and clutch and TOB?
Glen
07-29-2017, 09:39 PM
Glen
Fidanzi aluminum flywheel, ram clutch, with supplied throwout bearing
07-29-2017, 09:41 PM
Ford T5Z
08-05-2017, 04:21 PM
08-05-2017, 05:54 PM
Cobra Make, Engine: Superformance, 427SO
Bill,
The problem is that you're trying to put the damn thing in up side down !
Sorry. Couldn't help myself.
Ted
08-05-2017, 06:04 PM
Are the pics upside down? They show normal to me
