Like Tree440Likes
LinkBack Thread Tools Rating: Thread Rating: 4 votes, 4.00 average. Display Modes
  #261 (permalink)
Old 12-09-2019, 06:00 AM
Bill D's Avatar
https://www.parts123.com/parts123/yb...Z5Z5Z50000027b
  #262 (permalink)
Old 12-10-2019, 03:22 AM
xb-60's Avatar
Thanks Bill. Will look good.
Seems like a variety of sources were used on early cars. I have a picture of Dan Gurney's '63 Sebring Comp 289 car that has rear number plate lights for roundel illumination ...whatever was on hand, huh?
I'm using Massey Ferguson dash lights.
Glen
  #263 (permalink)
Old 12-10-2019, 05:40 PM
Bill D's Avatar
Success! It took two tries but it formed the sides from one piece. Will build a holding fixture to hold everything in place for the welder.
snakeeyes likes this.
  #264 (permalink)
Old 12-10-2019, 10:30 PM
xb-60's Avatar
Nice work my friend! Looks like the work of a pro
  #265 (permalink)
Old 12-11-2019, 03:48 AM
1795's Avatar
Something to be proud of Bill.
  #266 (permalink)
Old 12-11-2019, 10:02 AM
Bill D's Avatar
Thanks guys. But I’m going to remake the side panels. It slopes too much. Going to raise the front 1-1/2”
  #267 (permalink)
Old 12-14-2019, 01:17 PM
Bill D's Avatar
I remade the sides. I raised the front 1-1/2”. Now it more closely resembles the one I copied and better fits under the hood. There’s a small gap in one corner but I think it can be welded closed.
[url=http://imgbox.com/q5uG35vB][/URL
  #268 (permalink)
Old 01-15-2020, 07:39 PM
Bill D's Avatar
After a week at a local welder (term used loosely) I got my cold air box back. What a disaster! The welds look like Stevie Wonder did them. And the guy tack welded the bottom! He knew what I wanted so I’m not sure what he was thinking.
  #269 (permalink)
Old 01-15-2020, 07:41 PM
Bill D's Avatar
I spent 2+ hrs using a flap wheel on my grinder to blend all those stupid tack welds smooth. Then finished with 80 grit sandpaper to clean it up.
  #270 (permalink)
Old 01-15-2020, 07:44 PM
Bill D's Avatar
I then added notches to clear the fuel inlet fittings. Not an easy task with a hole cutter attached to a drill. But rigged up a fixture and accomplished it.
  #271 (permalink)
Old 01-15-2020, 07:46 PM
Bill D's Avatar
I turned my attention now to sanding the inside. First with 180 grit sandpaper and then 220 grit sandpaper.
  #272 (permalink)
Old 01-15-2020, 07:50 PM
Bill D's Avatar
After sanding the outside like I did with the inside, I started installing it on the engine only to find out the base warped enough to put half the mounting holes out of sync. I had to open most of the air horn and mounting screw holes. Laborious.
After installing and uninstalling way too many times, I finally got everything to fit.
Three days to clean up and finish. Whew! Glad it’s behind me
  #273 (permalink)
Old 01-15-2020, 08:21 PM
jolsen42's Avatar
Way to go Bill, patience pays off and it looks great. Keep plugging my young friend. I say young because I'm older than you. You're almost there.
John O
jjo42
  #274 (permalink)
Old 01-16-2020, 03:41 AM
1795's Avatar
Very well done Bill. Looks nice and serves two functions. Not only does it provide cold air to the horns, but also serves as a nice container to hold jets, air correctors, etc. in case they slip out of your fingers. A lot easier then trying to fish them out of the manifold with everything in the way.
jolsen42, 1985 CCX and Bill D like this.
  #275 (permalink)
Old 01-16-2020, 06:48 AM
Buzz's Avatar
Very nice work - awesome project!
Bill D likes this.
Tropical Buzz
  #276 (permalink)
Old 01-17-2020, 07:44 PM
xb-60's Avatar
Great stuff Bill!
It's frustrating when the guy whom you're paying good money to do a good job doesn't share the same vision....or interpretation of "quality"....as you.
Glen
  #277 (permalink)
Old 01-27-2020, 03:32 PM
Bill D's Avatar
Two to three more weeks of prep and it’s OFF TO PAINT!
Seriously thinking of this paint scheme. Anyone know what color the red stripe is?
  #278 (permalink)
Old 02-01-2020, 02:03 PM
Bill D's Avatar
Spent today making an aluminum door panel.
I’m debating if I should epoxy two or three half ovals to the panel horizontally to replicate beading
  #279 (permalink)
Old 02-02-2020, 03:41 AM
xb-60's Avatar
Bill, I've just made an aluminium footrest for my car.....and you're making your own aluminium doors??
I trust your judgement.
Cheers!
Glen
edit: I reread your post in the light of day, and on something larger than my phone
It's door panels you're making. I did wonder why you would be making doors when you are only a matter of weeks away from paint.
Looking forward to see what you do with the new panels
  #280 (permalink)
Old 02-02-2020, 03:16 PM
Bill D's Avatar
Still have to finish sand the panel and countersink the river holes. I use flush mount rivets
