Old 10-21-2015, 06:53 PM
Cobra Make, Engine: johnex
Default Johnex hood trouble
I recently bought a Johnex Cobra that was in a fire. It is a flat side. I had to graft a new nose on it. Does anyone have pictures of hood hinges and how they are glassed into the body? Also, did the Johnex have inner fenders? What fastened the nose to the frame? Is it just the quick jack supports? The nose I am using is from a mystery car, but fit well. Could not find any pictures, would appreciate some and any help too! Been lurking the site for a while and seen lots of finished pictures of different kits...but none like mine.
Old 10-22-2015, 01:00 AM
Cobra Make, Engine: CR Cobra 3169
What a sad picture. Shows the importance of a good fire extinguisher. Sorry can't help answer your question.
JD
Old 10-22-2015, 04:23 AM
It burnt in 4 min they tell me. Once it starts it's hard to get out. Happened in his driveway. This car will be out in the spring I hope. Not much info on these johnex and they were built 1hr from my house. This one is tubed makes it stand out. Has a crazy stance couldn't leave it when I saw it
Old 10-22-2015, 05:01 AM
cobrakiwi's Avatar
Cobra Make, Engine: Coombe, Shelby Block 496
Nice project you have there.
This is what I make for both our Alloy and fiberglass builds, the hood frame and hinges are along the same design has the original cars.
The fiberglass panel gets bonded to the steel frame, there is a little more involved in the alloy hood.
I am sure you could come up with something close or if you need help pm me.
Old 10-23-2015, 06:22 AM
Cobra Make, Engine: dd cobra,351w mild cam
CSC Racing in Ontario Canada worked with Johnex building their chassis...they are still in business they may be able to help you...9059540520...18884893880..Ralph de Winter
steve
Old 10-23-2015, 06:29 AM
Would also like to see pics of your progress...steve
Old 10-23-2015, 09:24 AM
Ya csc is around the corner he was a big help but didn't know about the body part much. From what I gather there was a k frame glassed into to nose and hood bolted to that. I have one hindge so I can make the other side. Might come off the frame but hood alg is going to be a big problem. Not building a show car but Don't want to b a hack.
Old 10-23-2015, 05:57 PM
Cobra Make, Engine: 408w 500 h.p. 550 ft.lbs
If you are around the corner from Ralph, you are probably only a few minutes from me.
I have a 427 s/c, Johnex, not sure if the same hinge setup, but you are more than welcome to come over and have a look if that would help. PM me for address if you like.
Craig
Old 10-27-2015, 05:19 PM
Does anyone know how many johnex cobras were made.were they common?
Old 11-01-2015, 07:05 AM
Default Few more pics
Couple more pics of the burnt sadness...only took fire department 4 minutes to put it out!!
Will be adding more to my album "CT Clint's Cobra Rebuild" shortly
Old 11-09-2015, 07:15 PM
Hey guys any chance of getting so more pics of the hood hinge structure. I think it is a glass k frame not sure if it goes all the way down to the nose. Worried about stress cracks if it isn't big enough. Thanks again
Old 11-10-2015, 01:55 PM
Sent you P.M. Rick.
