Like Tree46Likes
  #21 (permalink)
Old 01-12-2020, 02:23 PM
cobrakiwi's Avatar
Cobra Make, Engine: Coombe, Shelby Block 496
Thanks
Next up is fitting the radiator, I made up a new top plate for the rad to look more like the originals.
Once it's painted black it should look nice.
jehammer1952 likes this.
  #22 (permalink)
Old 01-19-2020, 07:43 PM
cobrakiwi's Avatar
Front inner panels made up and installed.
Oil cooler added along with the side vents and badges.
Bill D, xb-60, 1795 and 1 others like this.
  #23 (permalink)
Old 01-25-2020, 07:40 AM
cobrakiwi's Avatar
Steering rack in place and started on installing the brake lines.
  #24 (permalink)
Old 01-25-2020, 07:13 PM
xb-60's Avatar
Nice work....as always
  #25 (permalink)
Old 01-25-2020, 07:43 PM
ERA 626's Avatar
Cobra Make, Engine: CSX 6079 482CI CSX cross ram
keep the photos coming
  #26 (permalink)
Old 01-30-2020, 06:01 PM
cobrakiwi's Avatar
Pedal box complete and installed, all the brake and clutch hard lines installed.
  #27 (permalink)
Old 01-31-2020, 10:59 AM
ERA 626's Avatar
look how low the holes are for the heat shield over the brakes, mine on my CSX are an inch higher and the heat shield hits the pipes... This confirms the person who installed mine was drunk... add to the list of assembly issues with the CSX
  #28 (permalink)
Old 02-01-2020, 07:14 AM
cobrakiwi's Avatar
Next up, fitting wiring components to the firewall etc.
Voltage regulator on passenger foot box, (think I will paint that blue cover black)
fresh air valve to the foot box installed, wiper motor mounted.
Time to make up and fit the dash then roll out some wire!
  #29 (permalink)
Old 02-01-2020, 01:30 PM
ERA 626's Avatar
Default reg?
are you actually going to use the voltage reg or is it for show?
  #30 (permalink)
Old 02-01-2020, 01:35 PM
ERA 626's Avatar
is that a Kirkham car?
  #31 (permalink)
Old 02-02-2020, 07:37 AM
cobrakiwi's Avatar
Absolutely we will use it.
  #32 (permalink)
Old 02-17-2020, 12:57 PM
cobrakiwi's Avatar
Making up the steering column, needed to machine up a few steering wheel hub nuts.
  #33 (permalink)
Old 03-11-2020, 04:01 PM
cobrakiwi's Avatar
Next up I installed the diff, apart from the weight of the thing all went well.
  #34 (permalink)
Old 03-11-2020, 05:02 PM
1795's Avatar
Craig,
Looks nice. Yes, they are heavy. I recall struggling with mine during the install, a lot of weight and a tight space to fit it in.
Jim
cobrakiwi likes this.
  #35 (permalink)
Old 03-11-2020, 05:04 PM
Cobra Make, Engine: Kirkham #259
Kiwi
Are you aware of the bad bump steer on your steering.....??
Morris
  #36 (permalink)
Old 03-12-2020, 04:10 AM
cobrakiwi's Avatar
Originally Posted by Morris View Post
Kiwi
I haven't finished hooking the steering up yet or gone over any bumps so not aware of the bump steer yet.
Seriously but, if you have any setup suggestions, settings or measurements etc I am all ears.
Thanks for any help.
Cheers.
  #37 (permalink)
Old 03-12-2020, 03:13 PM
cobrakiwi's Avatar
Little more done today, radiator and fans installed.
Started in on the wiring.
  #38 (permalink)
Old 03-13-2020, 02:40 AM
xb-60's Avatar
Good progress!
How long do you anticipate the wiring taking? I haven't done one before....
Glen
  #39 (permalink)
Old 03-13-2020, 04:29 AM
cobrakiwi's Avatar
Originally Posted by xb-60 View Post
Good progress!
Glen
Hey Glen
It takes a few day's if everything is ready to go, a little longer at my pace.
xb-60 likes this.
  #40 (permalink)
Old 03-17-2020, 06:08 AM
cobrakiwi's Avatar
Waiting on a few items for the wire harness, time to start in on the control arms.
cobra and 1795 like this.
