99Likes
08-06-2019, 02:40 PM
va
Big Block Street
Starting a new project alongside the blue 427 SC build, what we have here is a csx 4k SC that will / is being converted to a street 427.
No roll bar, no hood scoop and under car exhaust.
Also a set of 5 real sunburst wheels are going to need a restoration.
At this stage, car stripped down, body removed, frame back from sand blasting
I need to fix a few things on the frame, replace some damaged tubing and fit some missing frame structure.
Should be an interesting and fun project.
08-06-2019, 05:36 PM
Looking forward to following this one Craig. Have fun.
08-06-2019, 05:55 PM
SA
Seems to be a little more interest in 427 roadsters these days. To me, they are more appealing than a striped SC lookalike.
Will be great to follow the build.
Glen
08-07-2019, 02:30 PM
va
Wow, it was a hot one today, so why not get into some welding.
Started welding up all the rivet holes not going to be used.
08-07-2019, 02:36 PM
va
Windscreen post mounts looked like Swiss cheese.
08-07-2019, 07:44 PM
Cool project! Going to be neat watching it come together!
Alba gu brąth
08-08-2019, 10:56 AM
va
Not sure what was going on here but it has to go, cut the ugly out and replace with new material.
The plasma cutter makes short work of removing the old cross member.
All cleaned up ready for a new cross member to go in.
The rear section is all cleaned up ready to go!
08-08-2019, 02:15 PM
Ya I am liking the street version more an more to. I made the buyer of my original 427 take the original rims. Who would want them !!
Dan
427 CSX 3000/4000 and Shelbys.
All gone ! Was a Hell of a run
Now ... The dogs car
Mercedes E63S station wagon. 603hp
08-08-2019, 07:10 PM
is this an HST car? or a Hi-tech car? the welds look bad...
08-09-2019, 02:29 AM
va
This is an early 4k car so would not be a Hi-Tech car.
The cross member is a modification to this frame by ?
And yes the welding/ workmanship falls a little short imo.
I think it would have stayed together but certainly not the best looking work.
We will get it straight with a new piece of tube and transmission mount setup, park brake bracket needs a little work as well.
Rest of the framework, welding included looks fine.
08-10-2019, 10:47 AM
Craig
Cool beans look forward to progress
08-10-2019, 11:40 AM
va
Originally Posted by 1985 CCX
Craig
Thanks Jeff
A lot of work but we will get there,
New cross member in, made up one of my tko mounts.
Things are looking much better now.
08-11-2019, 03:06 AM
Cobra Make, Engine: Hi-tech body/frame, 427engined FF5/302engined FF5 Bennett 289 & 427 rolling chassis
Wow! As always, your work is impeccable!
Albert Einstein
Two things are infinite: the universe and human stupidity; and I'm not sure about the universe.
08-11-2019, 03:28 AM
Yes, very nice, keep up the good work.
08-11-2019, 04:24 AM
va
Engine and gearbox all set, saved the park brake handle bracket. Ready to glue it onto the frame.
08-11-2019, 10:56 AM
The engine block looks a bit hinkey. Service block, or is it a Pontiac?
08-11-2019, 11:04 AM
trans tube
Kiwi, Have you ever considered using a removable tranny tube like the CSX (HI-tec) cars? Is tere a reason you dont?
08-11-2019, 07:43 PM
Interesting transmission mount! I like it! Do the mounting ears on the transmission actually sit on the cross member?
Alba gu brąth
08-12-2019, 07:42 AM
va
The block is one of our new billet plastic 1000 hp ultra lightweight versions.
After the ride along in your HiTech the other day I am going to need all the hp I can get to keep up with you!
08-12-2019, 07:44 AM
va
I did consider the removable cross member a few years back, but to be honest it's not that big of a deal removing the trans from the top/inside the car.
