99Likes
12-19-2020, 08:24 AM
And if you have a really sharp eye you will see that Bob P. actually labeled that ground wire as "66" and, sure enough, if you go to the ERA wiring instruction manual you will see that connection 66 is titled "GROUND FOR FUEL FILLER PIPE" and that black wire leads to the rear bumper bracket ground point.
12-19-2020, 09:38 AM
... and what are those three small clear hoses for?
12-19-2020, 01:33 PM
The street cap is a little different although end result is the same. Mine is turned towards the outside and hard to see but I’ll see if I can get a picture of it.
12-19-2020, 04:02 PM
Originally Posted by cobrakiwi
Is this the vehicle you have seen many fires in because of no fuel neck ground strap?
I see that this vehicle had a call back for a possible fire hazzard due to a faulty alternator wire etc.
I did a Google on it but coming up with nothing, would you have a link to a news report or something backing your claims?
Thanks much.
It took a few complaint instances for Holden to work out what was happening.
Then the rework techline came out to add the ground strap to affected vehicles.
Unfortunately, I can't locate the techline copy right now. I could have a hard copy of it to scan, but I need to did some old books for that.
Suffice to say, if you google "fuel filler pipe ground", you will see many instances of what can happen without the ground strap connected.
As Patrick has said, the strap is to ensure the filler neck flange (this is the point of contact by hand and fuel bowser nozzle) is held at the same potential as the rest of the metalwork.
12-20-2020, 12:46 PM
Dan
Would you have a picture of how ERA, or you have added the wire to your fill cap neck?
Well, I keep forgetting this is the only auto forum I can't post pictures too anymore because I don't have a photo storage account any longer and can't paste from my computer. Basically ERA tacks a threaded stud to the down pipe section coming off the filler and a ground wire going underfloor to the frame or the tank. If you would like me to email a picture pm me your email.
Dan
12-20-2020, 01:10 PM
Dan
This forum gives you like 100 megs of space to upload pics and I just looked and you haven't uploaded even one. Just click on the camera icon under your name on any of your posts and then choose "Upload Photos" from the upper right of the screen. It's really easy. I mean, really easy.
12-20-2020, 04:30 PM
Yeah - I haven't used that - keeps wanting me to resize my files. Everything's a frickin pain in the ass.
12-20-2020, 04:54 PM
SA
Originally Posted by Gaz64
....the strap is to ensure the filler neck flange (this is the point of contact by hand and fuel bowser nozzle) is held at the same potential as the rest of the metalwork.
OK. I'm convinced. My fuel filler needs a grounding connection.
Gary, does a braided strap have any advantage over an insulated wire?
Glen
12-20-2020, 05:21 PM
Glen
I don't see any advantage, one over the other.
Either one will produce near zero ohms.
It doesn't need to be over-engineered, so no Sydney Harbour bridge. Lightweight and functional.
12-20-2020, 06:23 PM
va
I wonder how all the motorcycles etc with steel and aluminum rubber mounted fuel tanks get away with out ground straps and not bowing up at the pump?
Like I said, the video in the previous post (95) says it all.
12-20-2020, 06:54 PM
Yes, that is a good question.
Now I'm off to find the answer, maybe.
Similar scenario in boats:
https://www.rib.net/forum/f36/ground...ank-42459.html
05-01-2021, 01:29 PM
va
Been a minute or two but back on this one, got the clutch and brake pedals made up and installed.
05-09-2021, 06:51 AM
va
Cover plate for around the pedals made up and installed.
05-09-2021, 01:56 PM
Looks nice. Another happy customer Craig.
05-09-2021, 03:51 PM
IN
Cobra Make, Engine: ERA 838
You do nice work.
I like the seal for the pedals. I put something similar in the last ERA. This build is going to look more like what you did.
05-09-2021, 08:04 PM
SA
Very nice work Craig! I'm feeling like I should be reworking my pedals somewhat
Cheers!
Glen
Reason: edit
12-17-2021, 04:11 AM
va
Finally got a front corner on this one, been waiting on a part of two
Then top it off with the shinny bit.
