08-12-2022, 08:36 PM
NV
Just waiting for your Cobra
CSX4005LA
08-12-2022, 09:21 PM
SA
Wow, that is one very compact 90° Vee engine (height-wise, at least)!
I think it's outside my budget though
Cheers!
Glen
08-12-2022, 10:12 PM
WA
The Sound, Ol 'Lordly the sound!!! Best music you're every hear
08-12-2022, 11:06 PM
SA
Tony - this is the one I'm thinking about....
Should fit  ...yes?
I think it's a Ford engine. Says F.... something or other
08-13-2022, 05:30 AM
Possibly just a conversation piece for the garage.
This is copied from the auction site write-up.
The piece is currently used as a display item and it is not known if any of the original internals are present.
08-13-2022, 02:00 PM
NV
Yes, it's probably best used as a coffee table.
Look at the exhaust headers. Makes the GT40 look simple.
I always liked the sound of a Ferrari V12. But the sound of a 20K RPM V8 has to be even better.
CSX4005LA
08-13-2022, 02:03 PM
NV
I kinda doubt it would actually fit width-wise in a Cobra. But more than one have squoze a Cammer in one.
CSX4005LA
08-13-2022, 08:45 PM
If you look at the front of the engine, all the cam drive, oil pump. water pump and other accessory drive hardware is missing. Additinally there is no crank snout or flywheel flange visible which probably means the entire rotating assembly is missing. I suspect it is a block, heads and headers. It would be a good bet the heads are empty castings.
Stil in all, a very impressive coffee table...
08-13-2022, 10:21 PM
SA
Originally Posted by twobjshelbys
.... the sound of a 20K RPM V8 has to be even better.
Appears that it would need 20k rpm as early figures showed 720 bhp but torque at merely 220 lb ft
Cheers!
Glen
Reason: edit
08-14-2022, 04:29 AM
WI
Definitely an awesome piece of garage art or man cave furniture! For the Cobra though, I'm thinking more along the lines of this that was further down the page.
https://silodrome.com/allison-v12-aircraft-engine/
Hood clearance might be an issue though and probably a heavier set of front springs...
Tropical Buzz
02-22-2024, 12:06 PM
I'd see that in a old Lotus 47 replica. Using RCR formula car.
