Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Contemporary Classic Forums
Old 05-11-2010, 11:08 AM
Cobra Make, Engine: Contemporary CCX-33711 427 S/O
Default Rear Axle torque spec
Does anyone have the rear axle torque spec? Upon replacing the broken Watts Linage bolt I found my wheel bearing was shot. I have no documentation so any guidance would be helpful.
I'm guessing around 50-60 ft lbs
Thanks in advance
Drew
Old 05-12-2010, 07:31 AM
If the bearing is running hot, it's likely that the hub spacing has been set up incorrectly.
Hub carrier adjustments
As you can see in the above link, the torque spec for the nut is 225 lbft, but that assumes that the bearing spacers are correct.
