Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Contemporary Classic Forums
February 2026
Old 07-09-2010, 01:29 PM
Default Motor Mounts
So I am trying to install a 427 into a recently purchased Contemporary Cobra, but have run into a few roadblocks. The car originally had a 351 in it (which is long gone) and sat in a shop for 13 years without any attention. I purchased the motor mounts specified in the manual for the FE (Anchor Doan 2222 and 2223). However, when I put the engine in the car with the motor mounts, I am a good inch or more away from the mounting holes in the frame! I have tried the motor mounts in every direction imaginable without much success and flipped sides as the manual suggests (they look identical to me though).
Can someone with a contemporary and a 427 post a few pictures of the motor mounts and maybe a few measurements? Measurements that would be helpful are the distance from the x-brace to the motor mount riser and the distance from the hole in the motor mount to the riser.
Thanks in advance!
Drew
Old 07-09-2010, 03:12 PM
FUNFER2's Avatar
Check with Olthoff , for Poly motor mounts. Expensive but nice.
Same goes for this guy.
http://www.craigscobras.com/parts/mounts/index.htm
The Kirkhams make a nice pair too.
http://clubcobra.com/forums/showthre...=engine+mounts
Do a search here, as there are many posts about engine mounts.
Regards,
Kevin
Old 07-09-2010, 06:55 PM
mickmate's Avatar
I'm pretty sure the motor mount pedestals on the frame are different from small to big block. I use the Anchor 58ish Thunderbird motor mounts from Rockauto.
mickmate
http://www.actoncustom.com/
Old 07-09-2010, 06:56 PM
Yeah, I think you are right about the BB vs SB. I'm hoping to confirm with some measurements before I start hacking up the pair of motor mounts that I bought to work.
Old 07-09-2010, 10:20 PM
mickmate's Avatar
We can get you through this. I can provide motor mounts for the CCX big block if you need them.
mickmate
