Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Contemporary Classic Forums
Old 09-08-2010, 01:55 PM
Default ccx ride hieght?
If your running 295/50-15 in the rear, 235/60-15 in the front, does anyone have a measurement from the bottom of the frame front to ground? and the same for the rear-the rear measurement at the bottom of the frame at the rear cross member the pinion sits on?
Thanks,
Daniel
Old 09-08-2010, 02:38 PM
mickmate's Avatar
Daniel you have the CCX manual don't you?
mickmate
http://www.actoncustom.com/
Old 09-08-2010, 05:41 PM
1985 CCX's Avatar
We can probably set him up!
Old 09-08-2010, 06:44 PM
Yes I have the manual.....I was just lazy, it's in the shop and well..I'm not.Thought some one might know it off the top of there head.
Daniel
Yes I 'll go look. It's time for a cold one.
Old 09-08-2010, 08:32 PM
Okay, page 13 thru 27 do not answer the question. Using a ride height gauge during install does not give you real world.
So......does anyone have time take beer break and use a good old fashion tape measure? lol.
Daniel
Old 09-08-2010, 09:32 PM
Daniel, Im running the same size tires with aladin shocks and my front is 25 1/4 from the ground to the fender well (on center line of axel) and the rear is 26 inches.You can check my gallery photos to see if its at a height that you like.and you can go from there hope this helps...Bob
Old 09-08-2010, 10:21 PM
Thank you!
Daniel
