| S |
1 |
| 2 |
5 |
8 |
| 9 |
12 |
15 |
| 16 |
19 |
22 |
| 23 |
26 |
29 |
| 30 |
02-28-2011, 08:53 PM
nc
Cobra Make, Engine: contemporary #3072 , 390 big block, red no stripe
redline?
cant seem to get a good feel for the max rpm for my 390 big block. I was wondering what was a safe rev limit.
thanks too all.
02-28-2011, 09:09 PM
AL
who build the motor and was it dyno'ed?
around here we can get a car dyno'ed for $50 to $100.
Dwight
02-28-2011, 09:14 PM
nc
the car was built out in vegas in the mid 80s. its a 390 thats been bored .030 over. hi pro intake with 750 pumper. tach has not worked since day one and is now fixed. I just drove it hard and by feel. I got all the bugs out this winter and dont want to float a valve.
02-28-2011, 10:08 PM
WA
Sounds like a "mystery motor" to me. Not knowing anything about the build OR builder I wouldn't take any unknown past 5000-5500 rpm on a good day. Most any big block is comfortable at 5500-6000 rpm for max HP. Good luck.
03-01-2011, 03:51 AM
AL
As much as I dislike MSD, I would suggest you install a MSD for the rev limiter protection and set it at 5500.
Dwight
03-01-2011, 05:56 PM
Ca.
My 390 has cast pistons and i have turned it to 6k with no problems (yet) and its 10 years old.....
03-01-2011, 09:18 PM
tx
Cobra Make, Engine: Lonestar LS 427, Keith Craft 501,Toploader
I think to properly find the rev limit of any engine, it would be a good idea to have it dynoed to see where the power starts to drop off. So, a little before the power drops would be the rev limit.
" It ain't no big deal"
03-03-2011, 05:03 AM
AZ
About 6K is the limit for my 428 FE..
Dan in Arizona
CCX3209
03-03-2011, 06:10 AM
CT
Cobra Make, Engine: SPF - 351W, 944 non-turbo
Remember, at 6,000 RPM those pistons are going up and down 100 times per second. Is there a need to go any faster?
Bob
03-03-2011, 08:09 AM
ca
Bob
Back in the late 70's and early 80's we were very heavy in truck and tractor pulling. I used to build various configurations of FE's from 390-432 inches and spin them up around 9000 rpm +. When they made the "big noise" the results were catastrophic. When these engines went south you were lucky to salvage the intake manifold. I had 1 motor with lifters jammed behind the flywheel. I wouldn't spin one with stock type components any higher that 5500 or how much $$ you can afford to spend, or whichever comes first.
