Old 05-09-2011, 04:13 AM
Registered User
Default No Signal Lights
Anybody have this problem? Signal lights no longer work. When I move the signal stalk, nothing. The hi-beam switch in the stalk works. The brake lights work.
The wiring schematic in the Contempory manual is very minimal; it gives no detail. It shows a signal light/brake light converter box. Could this be the culprit? Is it the size of a Hershey bar? But I have brake lights.
Does anybody have a DETAILED wiring schematic? I'll pay for one. I contacted Ron Francis a couple years ago & they asked for a serial #. Naturally it was missing. They wanted to sell me a new harness. No way.
Did get the brakes working, finally.
Old 05-09-2011, 08:59 AM
streetrod1927's Avatar
Cobra Make, Engine: Contemporary Classic Motor Car; 427 S/O
Default No signal lights
Check grounds and if bulbs are good (sounds basic but can be the problem) there should be double filliment bulbs (stop & blinker). Also signsal stat under dash.
Old 05-09-2011, 09:52 AM
mreid's Avatar
If the brake lights work, then the ground at the tail lights is fine. Do the lights come on at all, just not blink? Do your 4 way flashers work? If so, swap flasher units (large silver "cans" in the fuse box) and see if the problem moves to the 4 ways.
RCR GT40 SOLD to Fast 5
Kirkham #690 289 FIA
Old 05-10-2011, 09:53 AM
Registered User
It never came w/4-ways. Got brake lights. The high beam switch puts on the high beam. No signal lights whatsoever. Nothing. It doesn't look like power is going to the turn signal stalk. I will try to trace the hot wire going backwards.
Probably going to put a new harness in it. One that comes w/a detailed wiring diagram.
Old 05-10-2011, 12:40 PM
Default No turn signals
Uncouple the connection from the harness to the signal selector. Clean and re-seat. Also check for loose connections into the connector socket (both ends).
