Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Contemporary Classic Forums
Old 06-09-2011, 12:52 PM
Default water temp gauge not working
howdy--went for a cruise this am, when driving back, noticed my smith water temp gauge was at zero. everything else seems to be fine. thoughts? fixes?http://www.clubcobra.com/forums/imag...s/confused.gif
Old 06-09-2011, 02:17 PM
If it's mechanical about all you can do is rap on it with your knuckles and if that doesn't work you're going to have to replace it. If it's one of their electrical models then there's a chance the connections have gone bad or the sender has failed.
Old 06-09-2011, 02:41 PM
its the original i fear--built in '93. probably mechanical.
Old 06-09-2011, 02:55 PM
Mechanicals generally have a tube that is protected by spiraling wire that looks like this:
Old 06-09-2011, 04:24 PM
yep, that's what i got. word is that it is probably shot. after some research it seems they are not that dependable. i have a supply just down the road here in south minneapolis. 135 for a new one. damn.
Old 06-09-2011, 04:34 PM
The replacement is not that bad. Now I don't know CC dashes, but if it's pretty close to my ERA you just remove the dash screws, pull the dash forward a couple of inches, first try and go in from beneath while on your back with your head down by the pedals and your feet over the top of the seat, if you can't do that then go in down from the top with your hand to remove the screws from the back of the gauge, remove the fitting from the manifold, then snake the whole contraption through the grommet in the firewall. Do the opposite to install the new one. It sounds harder than it really is.
Old 06-09-2011, 04:39 PM
PANAVIA's Avatar
These mechanical gauges should be considered somewhat of a "consumable" item on these cars.
I see them go out much like light bulbs.
Dont loose the copper washer when you take the fitting apart
-- Steve
Old 06-09-2011, 07:24 PM
mickmate's Avatar
If you pull the seat closest to that guage you can get under and behind the dash. They have an liiumination bulb and a U bracket holding them in. Snake out and through with the new one, you may need a vibration loop or two to prolong the capillary tube life if you have length for it. When I get stuck on my back in these things like that I'll holler "someone get me a #2 phillips" and what they hear is "quick grab your camera and hold it steady between chuckles for a picture", just so you're warned ;-)
mickmate
http://www.actoncustom.com/
Old 06-11-2011, 06:51 PM
racco's Avatar
I replaced my water temp gauge last year and it lasted 200 miles. At least they will cover it under warranty.
Old 06-12-2011, 06:44 AM
fixed. 140.00 for the new one from the gauge guys(apt). they are just down the street! great luck. the smith repro looks slightly different on the face design, the type is slightly different, but that's ok. the biggest challenge was trying to stand upright this morning after spending too long yesterday upside down and crammed under the dash!
