Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Contemporary Classic Forums
February 2026
Old 06-15-2012, 11:17 AM
Cobra Make, Engine: CCX 3028
Default Contemporary Brake Master Cylinder
I have a Contemporary with Girling brake master cylinder from what looks like a Triumph Spitfire. The assembly manual calls out the specific Girling part no. and in my research it shows as a early to mid 70's Spitfire part. Has anyone changed out their brake master cylinder to a remote reservoir style? My setup is the overhung pedal arrangement. I want to upgrade to a remote reservoir style master cylinder since access to the reservoir is somewhat limited. I cannot seem to find anything that works. Any suggestions?
Thanks,
Tim
Old 06-15-2012, 04:04 PM
Cobra Make, Engine: HI-TECH 289 FIA
Willwood, and you won't have to use special brake fluid.
fiaroadster
Old 06-15-2012, 07:03 PM
Hi Rick 427 Cobra,
What Wilwood master cylinder did you use? The only one I have found has a 1" bore and I don't think that will generate enough line pressure.
Thanks for any info.
Tim
Old 06-15-2012, 07:15 PM
Thor maine's Avatar
I used a master cylinder from a late 70's mazda 626 or 828 I think . Remote reservoir I used PVC cleaner cans, drilled a whole in the bottom and put a fitting in. Looks just like the Girling original and works great cost $5 dollars.
Old 06-15-2012, 08:32 PM
They have 5/8 to 1 1/8'' Stock set would be about a 3/4 I guess
Wilwood High-Performance Disc Brakes - Master Cylinders
fiaroadster
Old 06-15-2012, 08:48 PM
mickmate's Avatar
PhotoPost Classifieds - CNC dual master cylinder with adjustable bias - Powered by PhotoPost Classifieds
There's a cheaper alternative to the floor mounted box I make.
http://www.clubcobra.com/classifieds...t=3394&cat=500
What about converting that frame extension to a bracket like this.
Anyone With Contemporary Brake/Clutch Info
mickmate
http://www.actoncustom.com/
