Old 05-05-2013, 01:40 PM
Cobra Make, Engine: contemporary 351cleveland
Default contemporary rear bolt-on hubs/1985
I have finally made it back on line. Thanks to all who have responded. I hope these pics will help. The outer brg has spun on the shaft.
Old 05-05-2013, 02:07 PM
XJ bolt-on hubs are identical, bearing-wise. What is the stud hole pattern and the distance from the hub face to the small-bearing end?
Old 05-06-2013, 04:29 PM
stricklypersonl, thanks for the info. xj hubs should be easier to find.
Old 05-06-2013, 05:19 AM
mickmate's Avatar
Those look like the CCX conversion from E type wire wheel hubs to a bolt on. As Bob says they should be the same. If you get some dimensions or want to put another hub alongside them let us know.
mickmate
http://www.actoncustom.com/
Old 05-06-2013, 04:26 PM
mickmate, you have shaken some cobwebs from this old brain. I do recall Peter saying that my original hubs were wire wheels. The bolt pattern is 4.5 in. The dimensions are hard to read in the photos. The dimension from the flange face to the brg is approx 2.25in. burdman
Old 05-07-2013, 04:46 AM
mickmate's Avatar
How did you measure the pattern? Wheel Tech - Bolt Pattern
mickmate
Old 05-07-2013, 05:21 AM
It looks like your current hub offset is substantially different from the XJ. That means, without the addition of spacers, your wheels will move in. I've attached a drawing of the stock XJ hubs.
Hub Drawing
Old 06-02-2013, 11:29 PM
racco's Avatar
Default Ccx hubs
I have two of those hubs in perfect condition from my ccx pm me .
Rocco
