Old 07-17-2013, 08:12 AM
Cobra Make, Engine: Dax Tojeiro, 450bhp 383 ci Stroker, Tremec TKO and Contemporary CCX, Big Block Ford, old school.
Default CCX Steering Geometry
Hi Guys, I now have CCX3 4028 on the road here in the UK.
I still need to set up the steering geometry.
what are the recommended settings for toe, castor, camber etc?
Please help before I destroy my new Avons.
Thanks for all the help and advice given during my build too.
Kev Davies, Wales (UK)
CCX-3-4028.
445 ci Ford FE
Old 07-17-2013, 10:50 AM
Thor maine's Avatar
Should you use the settings for Jaguar XKE or through trial and error, have CCX owners come up with a better settings?
Old 07-17-2013, 01:07 PM
mickmate's Avatar
Hey Kevin, congrats that's big news. I would run around 1/16-1/8" toe in, Jag manual says 2 deg+/- 1/2 caster, CCX manual says 3-5, more being heavier at low speed with better self straightening. Jag manual says 1/4 +/- 1/2 +ve camber, CCX manual says 0 or a tad -ve if you're a corner carver. Do you have the manual?
mickmate
http://www.actoncustom.com/
Old 07-17-2013, 06:56 PM
If he doesn't have the manual , I can send to his e address.
Old 07-18-2013, 02:57 AM
Thanks guys,
I have the CCX build PDFs and a XJ manual.
Mine being a late model isn't covered in the CCX pdfs.
I'll get it measured first off and see where I am.
I have crude camber gauge and I think I'm around 0 camber on one side and about 1/2 degree neg on the other, this is with no shims.
To achieve negative on the other side I'd have to machine the top wishbone mounting blocks down a little.
I have adjustable castor so that should be easy enough.
CCX-3-4028.
445 ci Ford FE
Old 07-18-2013, 05:13 AM
Is the XJ manual PDF or electronic? I'd sure like to have an XJ manual.
Old 07-18-2013, 08:10 AM
FatBoy's Avatar
Originally Posted by redmt View Post
PDF or electronic?
Isn't that he same thing?
Paul
Old 07-18-2013, 08:24 AM
Paul
DUH!!!! I meant hard copy or PDF. What day is it anyway,,,,,,,,,,,,,,
