Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Contemporary Classic Forums
Like Tree1Likes
  • 1 Post By Danr55
Old 02-12-2018, 01:42 PM
Dennis Mosley's Avatar
Cobra Make, Engine: Contemporary CCX33849 (currently 460)
Default Need to verify what front end I have
Hi guys,
Can you guys give me an ID on this front suspension. Is it Jag?
There appears to be an adapter bolted on to work with the wheels that came with the car. What would I need to do if I wanted to change over to knock offs in the future.
Thanks
The future is no place, to place your better days....
Old 02-12-2018, 11:06 PM
767Jockey's Avatar
Originally Posted by Dennis Mosley View Post
Hi guys,
Thanks
Dennis, hard to tell since I can't blow up the photos to see better, but from what I see that's a Jag based suspension modified by Contemporary to eliminate the stock torsion bar and incorporate a proprietary Contemporary coil over setup in it's place. As for the adapters, I haven't seen anything like that. My car came with bolt-ons, I replaced them with Vintage Wheels knockoffs, they're 5 pin knockoffs that come with the adapters. Bob at Vintage knows all about what offset works with Contemporary cars.
Hope this helps,
Doug
Old 02-13-2018, 06:16 AM
Hope this helps,
Doug
Thanks Doug!
Old 02-19-2018, 04:28 PM
Danr55's Avatar
Dennis, It looks like a Jag Series III front end.. to change to knock-offs, the adapter plate will bolt on the existing studs. You may have to shorten them just a bit as I did. Make very sure you torque them on as instructed and bring each one to full torque. Someone we know did not do that and lost a wheel at the track. It was scary but kind of funny also. See this car rolling down the track and it's rear wheel passing the car.. also be sure to use plenty of safety wire..
Dennis Mosley likes this.
Dan in Arizona
CCX3209
