Old 05-13-2019, 08:19 PM
Default Nutsert or nut rivet or rivet nuts used to secure steering rack
Thanks again for the manuals!
The top bolt that secures the steering rack has stripped out. I ended up looking up the frame with a borescope and what do I find. A couple of nutserts.
Has anyone else dealt with this or know anyone that are familiar with the installation of these in the Minneapolis,MN area?
I have talked to a few mechanics and Fastenal about them and they don’t think they should be used for that heavy duty of an application.
According to assembly manual(I received) it shows a nut on backside not a nutsert.
Old 05-14-2019, 07:10 AM
bobcowan's Avatar
Nutserts are a great way to install some things on a thin panel. But, I agree, they are not nearly strong enough for a steering rack.
If you can get to the back side, use a bolt and nylock nut. If not, then use a thread repair.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
Old 05-14-2019, 04:23 PM
Grubby's Avatar
Cobra Make, Engine: ERA 838
I wouldn't use a nutsert. If you can get to the back side put a nut in. If you can't, you could drill it out and weld a nut in place.
Old 05-14-2019, 06:44 PM
We use Clickbond products quite a bit during aircraft manufacturing. Quite easy to replace later on as well in the field. Fishing the nutplates into place using Weed-eater string works well. https://www.clickbond.com/
Old 05-14-2019, 10:46 PM
Thanks for the input guys and I will check out the clickbond.
