Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Contemporary Classic Forums
November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Like Tree2Likes
  • 2 Post By AC Ventura
Old 05-05-2020, 07:00 AM
Cobra Make, Engine: Contemporary Cobra
Default taurus fan for fluidyne radiator
is anyone using a taurus 2 speed fan with a fluidyne radiator? Any pictures how you attached it to the radiator?
jon
The Impossible Only Takes A Little Longer
Old 05-05-2020, 08:42 AM
AC Ventura's Avatar
Cobra Make, Engine: AC Cars Limited, 302 EFI
Default Taurus fan
My car is an AC Mk IV and I used the standard 302 radiator for the 427FE swap. Its a similar rad to the Fluidyne, but has a smaller 3", not 3.5" core. I modified the shroud, by making fiberglass mouldings that enable it to be attached to the radiator with radiator cable ties. Works perfect if you use the Volvo controller and BMW radiator, M22 thread, dual temp switch. My FE can idle in traffic for an hour, in summer traffic with the fan alternating between high and low speed. I also fitted two warning lamps to the dash, so I can see which speed is coming on.
1985 CCX and joyridin' like this.
Old 05-05-2020, 10:45 AM
MOTORHEAD's Avatar
Cobra Make, Engine: KIRKHAM 427 S/C, SHELBY 427 ALUM. STROKER
Jon : I installed mine in my Kirkham, and I think the most difficult part was getting it in behind the radiator. Brand of radiator shouldn't matter that much. Cobra replicas have the radiator in many locations and angles , from tilted fwd to aft and every degree in between.
My kirkham (and the originals) have the radiator layed back just enough so it looks like you could pull it out from the top ( quick change in the pits ?) but the bottom half is within an inch of the steering rack, no way is the shroud going to fit. I had to cut the lower half of the shroud off to the point that the shroud sits on top of the rack, and it stil was too high on top, so I had to add a metal strip to the top of the radiator. however it works great !i
"When Injustice becomes Law,
Rebellion becomes Duty." T. Jefferson
Old 05-05-2020, 11:26 AM
1985 CCX's Avatar
When I di that swap in my CCX I purchased a low profile efficient fan from Speedway. It works perfect and was very low profile allowing more than enough room which a std CCX has plenty of.
It attached via pull tabs through the core, designed that way.
I live in the NE so larger diameter was not necessary. I would in hindsight just maximize diameter to best suit the cooling as we all know these cars heat up.
