Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Contemporary Classic Forums
Old 09-21-2020, 07:22 AM
Cobra Make, Engine: Contemporary Classic Cobra CCX-3-3967
Default Side Pipe Ground Clearance
I'm building a Contemporary Classic Cobra from 1996 and wanted to see how much ground clearance other Contemporary cars have from the bottom of the side pipes to the ground at both the front and back. I currently have 4.5" for the oil pan but only 3 1/4" on the passenger side side pipes and 3.75" on the driver side. Other clearances are 5 3/8" at underside of body at oil cooler. 3 1/2" at bottom of front control arm at the rear pivot point. Front of frame behind front wheel is 6", rear frame is 5" in front of rear tires. My garage floor isn't level, and I believe I may raise the rear some by tightening up the 4 rear coil over shocks.
Mike
