February 2026
Old 04-22-2022, 04:10 PM
Default Larger Front Brake Rotors
Has anyone replaced their 11" front rotors with larger diameter rotors on a CCX Cobra? Any info on your build, parts and results would be appreciated.
Old 04-25-2022, 06:39 AM
Cobra Make, Engine: Contemporary Classic Cobra CCX-3-3967
I upgraded from the standard 10.5" Diameter to the 11" Diameter rotors. I would think you might need to switch to a radial mount caliper to go to a larger diameter yet. A radial mount caliper would not have required modification as the Wilwoods I had required modification to prevent hitting the upper control arm.
Club Cobra - mvanhorn8893's Album: Front Brake Rotor Upgrade
I'd also like to learn if anyone has went to a larger rotor and how they accomplished it.
Old 04-25-2022, 07:59 AM
Can anyone identify the part number for the 11 inch rotor shown in the picture. I am trying to find a replacement for my CCX
Old 04-25-2022, 08:13 AM
LMH's Avatar
LMH LMH is offline
I had 12.19” rotors and Wilwood calipers on my Hurricane with 15” wheels. They were about as big as you could go with those wheels.
Alba gu bràth
Old 04-25-2022, 08:33 AM
Here is the one that I have:
https://www.terrysjag.com/product/JLM776X.html
I have the knock off hub so I don't know if it is differt than the one in the photo with studs.
The ones I used for reference were Brembo C 32 764 E / CAC 2647/ C 41 942 Jaguar-Daimler F
Old 04-25-2022, 10:26 AM
I agree with Larry. I have 12.2" rotors up front on my ERA 15" wheels with six pin hubs and I don't think you can get any bigger than that.
