Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Contemporary Classic Forums
November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 02-24-2023, 02:27 PM
Default Rear Carrier Hub rebuild (outer fulcrum)
I'm replacing a damaged rear carrier hub. The OUTER FULCRUM in my CC Cobra has plastic bushings (polyurethane or Delrin?) ... vs steel bearings/races in the original Jag.
Did Contemporary Classic typically replace the original Jag bearings/races with these plastic bushings ... or was this likely done later by an owner?
Any idea who makes these plastic bushings, and part no?
Any thoughts as to which approach (bearings vs bushings) is best or the pros/cons of each?
Old 02-24-2023, 03:17 PM
Cobra Make, Engine: Contemporary Classic Cobra CCX-3-3967
Default Rear Carrier Hub rebuild (0uter fulcrum).
I believe Contemporary had someone make those as I received a set with the kit I bought. The original owner bought them at the time from Contemporary I believe. See photos in my album.
Club Cobra - mvanhorn8893's Album: Suspension Question
I didn't wind up using mine. I upgraded to Team CJ bronze bushing.
Team CJ system bronze
I've been satisfied so far. I've only driven around 1000 miles so far.
Complete IRS bronze bushing set (mid 1963 thru XJS)
Includes inner fulcrum and outer hub carrier bushings TCJbbsetL $495
Submit
Old 02-24-2023, 04:16 PM
Tom Wells's Avatar
m,
Another recommendation for Team CJ. Their parts are a bit steep but worth it.
Tom
Old 02-25-2023, 06:22 AM
Grubby's Avatar
Cobra Make, Engine: ERA 838
The Jag type bearings would be far superior to polyurethane.
The bearings have no give and will last a lifetime.
No give will yield more predictable handling.
John
Old 02-25-2023, 06:48 AM
joyridin''s Avatar
If you decide to go with polyurethane again, you might be better off having some made out of 75D polyurethane instead of that red stuff that is commonly used. It is almost the same hardness as delrin but has a memory like polyurethane.
I have Team CJ in mine. Work great.
Old 02-25-2023, 08:08 AM
Thor maine's Avatar
The poly bushings were made by a company named Concours West Ind. CWI.
Old 02-25-2023, 10:22 AM
Thx for the quick response. I ordered the bronze bushings from Team CJ.
By the way, here’s a pic of the old/damaged rear hub.
